tow bar
How-To articles ONLY go here.
bonerp
tow bar
Post by bonerp » Sat Jun 11, 2011 9:47 am
I want to either fit or get fitted a detachable tow bar with dedicated wiring. Had quotes around £595-£630 to fit and seen a kit for £437 to fit myself.
Had anyone done this? Is it easy? I dont think it needs coding using the dedicated wiring.
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
IanP
Re: tow bat
Post by IanP » Sat Jun 11, 2011 11:29 am
It is easy, you might need a hand getting the rear bumper off without scratching it though. If you get one with the proper wiring harness and relay its plug and play.
Neil48is
Re: tow bat
Post by Neil48is » Sat Jun 11, 2011 1:55 pm
Try PFJones.co.uk I got my Westfalia detachable from them for £265 inc P&P and i think they do the electrics for around £100 aswell.
Re: tow bat
Post by X5Sport » Sat Jun 11, 2011 2:13 pm
The OEM version comes with an additional module that alters the DSC parameters when a trailer is connected. What the effect is of non-OEM with regard to coding I don't know. Mine came direct from the factory as part of the order for the car.
bonerp
Re: tow bar
Post by bonerp » Sun Jun 12, 2011 11:35 am
thanks - pfjones looks to be a good price.
does their witter set up come with a cross bar or is it just a replacement detachable bar? Its not clear.
Neil48is
Re: tow bar
Post by Neil48is » Sun Jun 12, 2011 1:09 pm
I would imagine that the Witter includes the crossbar. For the extra that it costs i would go for the Westfalia,it has a higher towing capacity and is what is fitted by BMW themselves.
stevox5
Re: tow bar
Post by stevox5 » Sun Jun 12, 2011 1:46 pm
Having fitted both I would go for the westfalia its better quality and easier to fit as the bolts for the replacement bumper irons are secured better and make fitting easier. Go for the oem electric kit too.
Steve
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade,  Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
bonerp
Re: tow bar
Post by bonerp » Mon Jun 13, 2011 1:41 pm
ok thanks westfalia it is.
I'm sure I have seen a video somewhere on interweb how to fit this (may have been from XOUT, but have searched on usual sites but cannot find it - anyone have a link handy?
Is there any drilling required or just pretty much plug and play/bolt up?
Neil48is
Re: tow bar
Post by Neil48is » Mon Jun 13, 2011 2:34 pm
I fitted mine in a couple of hours,the hardest part is lifting the bumper on & off,you really need two people to avoid any scratches etc. But other than that its pretty straightforward.
B5tew
Re: tow bar
Post by B5tew » Wed Jun 15, 2011 2:26 pm
I fitted a Westfalia, supplied by PF Jones, to mine and the worst bit is fitting the trailer relay you have to cut the existing plug off of the loom in your car and you get a bag if crimp connectors to go on the wires and then put them into the connector they supply. The crimp connectors are not that good so I soldered mine just in case one decided to fall out.
Also when I started the car when I had finished the 4x4 light was on but went out as soon as i drove it.
I would recommend the Wesfalia as it is what BMW use as factory fit there is even a recess on the lefthand side of the boot for the detached bar to fit in.
Have a look at this thread
viewtopic.php?f=8&t=2068&p=21004#p21004
Hope this helps
Stewart
2015 Space grey 30d F15
storminmike
Re: tow bar
Post by storminmike » Wed Jun 15, 2011 10:10 pm
I see the detachable towbar bits on ebay a lot.....do they get knicked or something?
What's wong with a permanent bar apart from looks....can the be neat?
Nige
Re: tow bar
Post by Nige » Sun Jun 19, 2011 6:07 am
[quote=""storminmike""]I see the detachable towbar bits on ebay a lot.....do they get knicked or something?
What's wong with a permanent bar apart from looks....can the be neat?[/quote]
The removeable ones loof mean when you don`t need a towbar, the car looks much neater (IMO).
I fitted the Westfalia one in a couple of hours. Just take your time, follow the thorough instructions and its easy. I`d definately get the electronics moduls at the same time :thumbsup:
bonerp
Re: tow bar
Post by bonerp » Thu Jun 23, 2011 10:24 pm
had a westfalia kit fitted in the end with dedicated wiring. However, the parking sensors dont work now - whether connected or not.
Is this right? Does your parking sensors work without the towbar being fixed up?
Neil48is
Re: tow bar
Post by Neil48is » Fri Jun 24, 2011 8:10 am
Hi as far as i know the sensors are only supposed to stop working when you have a trailer etc connected to the electrics.
Re: tow bar
Post by X5Sport » Fri Jun 24, 2011 9:57 am
Correct, rear parking sensors should work until a trailer is plugged in. That's certainly how mine work (OEM). Front's unaffected. Sounds like a wiring fault.
