rubbing noise from an o/s wheel
bonerp
Post by bonerp » Tue May 10, 2011 3:39 pm
I have a rubbing noise that is very noticeable when driving along the side of fences and hedges etc.
Wheels are not particularly hot.
Any ideas / what should I check?
thanks
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
x555
Re: rubbing noise from an o/s wheel
Post by x555 » Tue May 10, 2011 4:42 pm
Sticking caliper maybe??
pvr
Post by pvr » Tue May 10, 2011 5:11 pm
Reflections can make things sound awful whilst there is nothing wrong. Rubber noise on the road, wind through the calipers etc could make it sound like that.
911 50th anniversary -
IanP
Post by IanP » Tue May 10, 2011 11:10 pm
[quote=""x555""]Sticking caliper maybe??[/quote]
I would second that, sounds like a brake pad is just kissing a disc
bonerp
Post by bonerp » Wed May 11, 2011 8:14 am
Will check this out thanks chaps. My brakes have felt a bit inconsistent and grabby so may be that.
I checked the discs too and they look a bit worn. Might chuck some new ones on while the wheels are off.
blingsta
Post by blingsta » Sat May 14, 2011 6:35 am
can you hear the noise after a certain speed? wheel bearing?
ianmaney
Post by ianmaney » Sat May 14, 2011 8:21 am
Check the protector plate on the rear disks, they sometimes touch slightly, I get this with mine, just stick a long screwdriver through the spokes on the wheel and push it back a little, see if it helps.
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
bonerp
Post by bonerp » Mon May 16, 2011 9:07 pm
thanks - rear disc looks a bit knacked and and fronts don't look much better. Do all the pistons just push back in the calipers? Anything special to consider in changing them?
Anyone bought these? they seem good value....
http://cgi.ebay.co.uk/BMW-X5-E53-3-0d-3 ... 1063wt_902
http://cgi.ebay.co.uk/BMW-X5-Performanc ... 2811wt_871
or any decent flat discs?
Raj
Post by Raj » Mon May 16, 2011 9:56 pm
The pistons will pull back a touch, but there are occasions when a piston can stick which is when you get issues of noise and overheating of the pad/disc.
