Dis v57 SSS v32
wilkoturbo
Dis v57 SSS v32
Post by wilkoturbo » Thu Apr 14, 2011 5:03 pm
Afternoon all has or does any one know how SSS works ive done the key coding but thats as far as I can go please help anyone thanks
Paul
bmw x5 le mans blue
wilkoturbo
Dis v57 SSS v32
Post by wilkoturbo » Thu Apr 14, 2011 9:48 pm
Bump
bmw x5 le mans blue
Rusty
Dis v57 SSS v32
Post by Rusty » Fri Apr 15, 2011 12:12 am
[quote=""wilkoturbo""]Afternoon all has or does any one know how SSS works ive done the key coding but thats as far as I can go please help anyone thanks
Paul[/quote]
Hey wilkoturbo, sorry nobody has managed to help, unfortunately I can't either. I was just wondering how the SSS connects, what the software does and how much it all costs.
Runabout - E92 3 Series Coupe
wilkoturbo
Dis v57 SSS v32
Post by wilkoturbo » Fri Apr 15, 2011 9:04 pm
bmw x5 le mans blue
jango-fett
Re: Dis v57 SSS v32
Post by jango-fett » Sat Apr 16, 2011 11:11 am
Regarding the SSS and the way it operates...
In order to code a car, the SSS SW will check that all of the vehicles ECUs are at the latest level (SW wise) before it will continue. If not, it will try to update/reflash the ECUs in the car providing you have all of the relevant files on your computer otherwise it will not progress.
In a dealership, the SSS machine is configured to work over ethernet using an OPS interface. The OPS interface has the K-Can diagnostic interface (D-Can) and MOST interface built in. In some of the more modern BMWs, the MOST part of the interface is required to update some of the infotainment ECUs so you might struggle to use the full functionality of the SW without the proper OPS interface.
Basically, the SSS can update the SW level on your vehicles ECUs, Code ECUs, and change certain coding bits/options (e.g .Window closing from remote, alarm bleep, etc)
Hope this helps...
What car do you have? Do you have the OPS head interface?
2002 4.4i Sport E53,Silver,Grey Leather,Comms Pack
2001, MINI One....
wilkoturbo
Dis v57 SSS v32
Post by wilkoturbo » Sat Apr 16, 2011 12:40 pm
Hi thanks for all the info all I have is the obd USB cable that works fine I've got all files just don't know what they do when SSS is working , car is 2006 3.0d le mans many thanks paul
bmw x5 le mans blue
jango-fett
Re: Dis v57 SSS v32
Post by jango-fett » Sat Apr 16, 2011 1:32 pm
Alternative BMW software would be... (also compatible with your USB obd cable)
Old GT1 - Coding, diagnostic, etc (SSS is just a modern update of some of this functionality for the new BMWs..)
WINKFP - ECU SW updates/flashing
NCSExpert - ECU/vehicle Coding
Ediabas Toolset - Diagnostics - same as INPA but less user friendly and more dangerous if you dont know what you are doing - a bit more vehicle knowledge required.
INPA - complete vehicle diagnostics / sensor monitoring
2001, MINI One....
wilkoturbo
Dis v57 SSS v32
Post by wilkoturbo » Sat Apr 16, 2011 3:38 pm
Wow thanks for the info I would like to update a few things so what sw would stop tranny lurch and tv in motion ? Thanks for all your help
Paul
bmw x5 le mans blue
jango-fett
Re: Dis v57 SSS v32
Post by jango-fett » Sat Apr 16, 2011 6:07 pm
Regarding the TV in motion, as far as i am aware it is not possible to activate it with the standard BMW dealer tools due to legal issues. It is possible using NCSexpert but you have to have the correct profile and know a few of the ins and outs of the SW. The resler tool and Software Penny has would be the easiest method to do this.
Regarding the Tranny lurch, the only thing you could do is ensure you have the latest SW version in your gearbox ECU (From what i have read, Jason is probably the guy who could give you an indication to what version should be on your ECU). Alternatively, Reset your ECU parameters/adaption - there are a couple of posts on here regarding that process.
2001, MINI One....
