Trying to find a 12v ignition feed and an earth in centre console for headrest screens.  Can anyone point me to the correct wires to use?
thanks
Paul
	Headrest screen wiring in console
				bonerp
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
- x555
Re: Headrest screen wiring in console
Don't know if there is one under there mate....i ended up sending one to the boot (purple/white wire on the radio control module)
Sanj may know if there is one up the front there????
I had to route my intravee cable to the centre console anyway so i did mine then
there is a good earth under there mind a 10mm nut iirc
						- Sanj
x555's suggestion is a gooden but if you don't want to lift everything up then ther is the fuse box to the right compartment. described here with piccy:
viewtopic.php?f=8&t=1036&p=11174&hilit=ignition+positive#p11174
Test it first though, no point goin to all that effort and finding it doesn't work. Should work when you switch to position two, just before the car starts.
Earth is where x555 has advised, you can use the cigarette socket earth too, that's a thick gauge wire.
