I am trying to do an engine oil change on my 2002 4.4 v8.
As far as I can see on the side of the sump is a small 17 mm plug with a hex hole in it.
The head depth of the drain plug is about 1/16th inch, hence near impossible to get any purchase on it before the spanner slips.
I have my doubts as to the dealer removing this plug and instead use a suction pump throught the dipstick hole , when doing the oil change.
Any ideas as to how to shift this plug as I have exhausted my stock of open ended spanners, ring spanners,sockets, allen keys to try and shift it?.
Lez
2002 4.4 oil change
- lezmtaylor
2002 4.4 oil change
- pvr
Re: 2002 4.4 oil change
Can't help you on the undoing, but the dealer does remove the bolt as on my 740 (same engine), they did not tighten it enough and I got oil everywhere on the floor in the garage.
911 50th anniversary -
IanP
You could try 'starting' the plug using a very sharp centre punch on the outer edge, or sometimes a pipe wrench will get a grip on the protuding part. If you go that route then I guess you will also need to fit a new plug
phiggystardust
hi lez
use an allen key thats fixed into a socket (special type) , these will turn it no problemo
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
AW8
I did oil service on the Z3 recently but the X5 despite 100k has been to main dealers for each service/inspection from new.
If your Bentley X5 service manual doesnt cover something this basic I suggest it is seriously lacking.
Hopefully g60renshaw or Jason will be able to advise - both handy with spanners & both have prefacelift 4.4i cars.
Sorry I cant help further.
