Fuel Gauge Sticking
Junkie
Fuel Gauge Sticking
Well, it didnt take more than a couple of weeks for something else to go wrong......
Filled, yes filled the X at Asda tonight for 94 quid and after the tell tale clicks on the filler and the twitchy round up to the nearest quid fiasco, the gauge reads half full (optimistic) or half empty (me).
As the screen also displayed 138 range, even I know the 4.4 is slightly better than that.
Had a look at some inconclusive stuff on Xoutpost, looking like a sensor problem at the moment.
*sigh
*sigh
- Sanj
Re: Fuel Gauge Sticking
PM Jig - he filled up with petrol in his diesel and got similar issues. Not that you did but sensors could be right!
- x555
[quote=""X5 CPE""]Well, it didnt take more than a couple of weeks for something else to go wrong......
*sigh[/quote]
Sorry to hear that mate you seem to be having a nightmare run with the x at the mo
lets hope it's a simple fix
*sigh[/quote]
- lezmtaylor
Hope you sort it , could be a dodgy connection on sender.
Lez
Lez
- pvr
I have only had this once in France earlier in the year, but whilst driving it, the meter moved slowly up to full (took about 80 miles or so). Never had it before, never had it since either.
911 50th anniversary -
- bullethead
Why haven't BMW solved all the electrical gremlins with 3 buttons on the dash CTRL,ALT,DEL
- Pewters
Fuel Gauge Sticking
No wonder the X5 has electrical problems, my mate stripped a write off and it needed two of them just to carry the wiring loom !!!
- Sanj
[quote=""bullethead""]Why haven't BMW solved all the electrical gremlins with 3 buttons on the dash CTRL,ALT,DEL[/quote]
They think they did with the Start/Stop button!
- jeegnesh
Fuel Gauge Sticking
There are two tank senders units in the tank that read the level, the range is nothing but a calculation by the computer based on the senders reading x mpg.
The needle again is based of the senders reading.
You can get into a hidden menu on your OBC and actually see those readings.
2 buttons/pins on the speedo one resets the mileage counter (left) and the other to alternate the obc view (right)
1. Press and hold right button till u get TEST NR 01
2. Press left button
3. Add up all the numbers this is your unlock code. Example 26131=13
4. think right takes u back to TEST-NR 01
5. Press right till u get too TEST NR 20 then left
6. Get locked message hit left till u reach ur unlock code then right
7. Goto TEST NR-09 and hit left
You now see the 2 sender results live if your driving
Unlock only needed once stays unlocked unless you disconnect the battery. And hold right to come out of this menu else switch off and on brings you back.
Alot of folks reported wrong values and after a couple of fills it was fine and never happened. However they also mentioned they followed up by filling super.
If it's sender issue one of the sender has the fuel pump attached so more pricey other is just sender so cheaper but still BMW prices.
Hope that helps. As you can tell I had far too much experience here.
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
- x555
Junkie
Cheers all, appreciate the responses.
I've been away on business for a couple of days and returned to find the needle and display reading somewhere close to the expected levels after a fill.
Wifey tells me it just started to act normally after about 25 miles, bizarre.
Anyway, I'm too busy to bother right now and while it's working I ain't gonna touch it guvnor......
- jeegnesh
Fuel Gauge Sticking
[quote=""X5 CPE""]Cheers all, appreciate the responses.
Anyway, I'm too busy to bother right now and while it's working I ain't gonna touch it guvnor......[/quote]
Sounds normal
this was what alot of other folks mentioned after 1-2 fills everything was back to normal.
Sounds normal
thedweeb
I think what happens is,very rarely the tank gets filled up which means the float on the sender rarely lifts to the max level. There then becomes a build up of residue on what is probably a pin that the float sits on thus preventing it to move. If that makes sense.
Black with Cream Pre-Facelift 3.0d sport.
