abs sensor problem
Sanj
Re: PROBLEM NO.2 :-(
Post by Sanj » Wed Mar 30, 2011 9:23 pm
If the OP permits, can we change the title of this thread to reflect ABS sensors? Would make a good point of reference for future searches? Some good info here...
If so, pvr - you'll have to do some work for a change! :poke:
pvr
Re: abs sensor problem
Post by pvr » Thu Mar 31, 2011 12:04 am
Changed it ...
911 50th anniversary -
Sanj
Post by Sanj » Thu Mar 31, 2011 12:29 am
Just one more thing to annoy you!
Can the search option be given the ability to see 3 letters? Put in 'abs' and it won't help... :|
Feel free to ban me.
x555
Post by x555 » Thu Mar 31, 2011 7:28 am
BAN BAN BAN BAN BAN BAN BAN BAN :fuelfire: :rofl:
jango-fett
abs sensor problem
Post by jango-fett » Thu Mar 31, 2011 10:47 am
[quote=""Sanj""]Just one more thing to annoy you!
Feel free to ban me.[/quote]
Maybe you should be buying mens health instead of searching on here for that. :-)
2002 4.4i Sport E53,Silver,Grey Leather,Comms Pack
2001, MINI One....
Rusty
Re: Re: abs sensor problem
Post by Rusty » Thu Mar 31, 2011 10:57 am
[quote=""jango-fett""][quote=""Sanj""]Just one more thing to annoy you!
Maybe you should be buying mens health instead of searching on here for that. :-)[/quote]
Lol, good call.
Sent from my mobile device using Tapatalk
Runabout - E92 3 Series Coupe
pvr
Post by pvr » Fri Apr 01, 2011 12:40 pm
You work in IT ??? I would sack you ...
Search for *ABS* :poke:
andym3
Post by andym3 » Sat Aug 27, 2011 1:01 pm
Today when driving along I seem to be getting the same problem again! :headbang:
My speedo is temperamental, my brake light and abs lights came on. Could the sensor really be nakered already? or could this be yet another bloody sensor?
Please help :(
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
fenj66
Post by fenj66 » Sat Aug 27, 2011 4:03 pm
hmm, i might have just found this thread just in time!
after 10 minutes of driving i am getting the warning gong and message "dsc 4x4 inactive" flashing up. the car still drives normally though.
if ive read correctly i need to investigate the nearside front abs sensor.. which i will do asap.
andym3
Post by andym3 » Mon Aug 29, 2011 12:06 am
Problem resolved! :D
Today I removed the near side rear abs/speed sensor and gave it a good clean up with brake cleaner. Also cleaned down inside the hole where the sensor fits into and cleaned the connection plug and gave it a quick spray with WD40.
Knew the sensor wasn't faulty as it's only a couple of months old.
Did take some pics, so will get them up asap. ;)
x555
Post by x555 » Mon Aug 29, 2011 8:37 am
[quote=""fenj66""]hmm, i might have just found this thread just in time!
if ive read correctly i need to investigate the nearside front abs sensor.. which i will do asap.[/quote]
Same symptoms as i had fella...for me it was the front nearside iirc.The front two are the same (not sure on the rears) so you could swap them to check if a clean up doesn't work.
All you need is an allen key to take the sensor out.
Good luck.
x555
Post by x555 » Mon Aug 29, 2011 8:39 am
[quote=""andym3""]Problem resolved! :D
Did take some pics, so will get them up asap. ;)[/quote]
Nice one Andy :thumbsup: . It's so satisfying when it's a simple fix and you don't have to take it to a garage ;)
andym3
Post by andym3 » Mon Jan 16, 2012 9:41 pm
Well here' the pics I promised. ASAP turned into a few months :lol:
shadrack
Post by shadrack » Mon Jan 16, 2012 9:59 pm
i had that exact thing, passanger side rear abs sensor 99%. they are also cheaper than a battery even oem, try resting the steering angle sensor google it but only takes 2 mins you turn lock to lock running or ignition (cant remember), i went through all them tries, you can test all the abs sensors from under the bonnet with a multi meter, ignion off pull big black multiplug from abs unit, 20 or so wires all numbered than google which pairs are which sensors because they are randomly placed and you will get e.g 3&8 front left, 2&13front right (THATS AN EXAMPLE), then with the meter on ohms (think again google) you will then get three with the same rough reading, and one with a totally obscure reading and thats the culprit or in your case it confirms it as yours has to be nearside rear as you have lost speedo and mpg, hpe thats of use
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Sanj
Post by Sanj » Tue Jun 07, 2016 12:52 pm
Does anyone have a picture of the ABS Sensor (andym3's pics don't show up)? I'm trying to find it on RealOEM with little success.
Think it's the reason for my yellow 4x4 light on the dash.
