But now I have discovered that to get to the node points it looks as though the driver seat will have to come out
BMW E70 Rear axle Air suspension
- Greydog
Well I think I have found where the water has been coming in, the bottom rear of the drivers door seal is flat the membrane is virtually non existent. I cleared the drains ordered a new membrane but not sure what to do about the door seal just yet.
Feeling a little out of love with my E70 just at the moment
OnlineLeslie
I have often though about cutting a slit in the outer door seal low down to let the water that collects between the inner and outer out as this is a silly design
I hope you can just move the seat to the limit of its travel to get near enough unless its under the carpet which no doubt it is
The door seal is probably fine if there are not cuts in it
Following the wiring back from the ehc to the front of the car hopefully shows up something .
- Greydog
Morning All
Well managed to unbolt the drivers seat and tip it on it's sider so I could get the carpet raised and check the loom. The loom actually runs in a very effective lidded plastic trunking so is protected from water ingress nice and dry and no sign of corrosion at the splice points. So I am now needing to borrow a good oscilloscope to test the bus systems as everything seems to be pointing towards a failing terminal resistor on one of the systems K-can PT-can or F-can seem the likely candidates
- Greydog
Well the lad with the oscilloscope will be here tomorrow so at last I may be able to get to the root cause of my issue. Best bit it will cost a couple of nights B&B real plus point I get the help of one of the best Industrial Control engineers around
As an aside the cars suspension is still at the level it was at when this started so definitely no leaks
OnlineLeslie
Lets hope for good news
- lezmtaylor
I will be sorry to hear the end of this saga, looking forward to the final episode !!!!
Lez
Lez
- Greydog
Well just finished running BMW's advanced Diagnostic sequence with young Richard driving the oscilloscope and it pretty much confirms my worst thoughts
the JBE is where the fault is, either a failed/failing termination resistor or another problem with it's PCB. Even putting it on springs is not as straight forward as it seems as the self leveling rear suspension is linked through the Flexray-can to the Vertical Dynamics Management and DSC
The E53 was so simple and straight forward, put it on springs code out the air suspension job done ???
So now I need to find out if (a) a new JBE is a financially viable option or (b) whether a used replacement is an option how simple or not would registering one to my chassis be (E53 again it took longer to physically swap control units than Registering them to the Chassis) On the plus side I have fitted a new drivers door membrane and yesterday tested it
it seems to have fixed the water leak
So Lez the Saga continues I am afraid
Well you have the answer i just hope replacing the JBE is straight forward for you.
Will be watching as normal.
- Greydog
Thanks Alan
I hope it is as straight forward as with the E53's (there a wild dream) today I will talk to my local Dealer see how much they want for the JBE, I will also start searching for second user parts and costs
On the plus side had a great couple of evenings with an old friend and colleague
- Greydog
Well after talking to several people and companies I have received all sorts of information and advice from "just get the same Part Number mine worked fine" to "Don't mess with it you can Brick the car" and of course "Only possible with a New OEM JBE at the Dealer"
The way forward I have decided is (1) Find a JBE that matches the Part Number or it's Retrospective replacements (2) Remove my JBE and send both off, Mine for repair if possible, the replacement for Cloning from my Original. That way I will have either my original back repaired
or a Cloned copy that will come with a warranty. Best result is a repaired OEM part and a spare in the Garage in case ?
Just hope your next post is good news.
I would have lost heart in the car by now if it was mine.
- Greydog
Morning Alan
The crazy thing is the car is in use almost every day the rear suspension doesn't leak, just the palaver of actually tracing the fault and then finding a fix. When I was in Business we used multiple Bus systems to provide resilience and redundancy. Who ever configured the E70 Bus systems clearly never read that book
It would be easy to sell on or scrap the car but that just hides the problem or passes it on, my Engineer head has to understand why and find a way to fix it. Hopefully that will be soon
I am a Ham radio operator and needed to learn a fair bit about electronics to get the license (was some years ago and forgot a lot).
This Bus systems and all the stuff used in our cars is alien to me and at my age will stay that way lol.
Best i can offer is to keep my fingers crossed for you.
