Aircon blowing cold on left but warm on right side vents E70
Post by Leslie » Wed Aug 26, 2026 5:47 pm
Anyone had an evaporator expansion valve replaced on a RHD car ? ,The part is cheap but I had a look and it appear to be behind the dash which is obviously a major pain The 2 pipes go in the bulkhead and I expect the valve is right the other side of this . Removing the dash is just not an option I fancy paying for :headbang: Its criminal to fit it the wrong side of the bulkhead ! :fuelfire:
Post by X5Sport » Wed Aug 26, 2026 7:43 pm
The good book says it is NOT a dash out job. The ‘special tool’ looks like a cone to make sure the ‘o’-rings aren’t perturbed.
The final instruction is to evacuate and refill the AC system.
Post by Leslie » Wed Aug 26, 2026 10:43 pm
Thanks you very much sir :thumbsup: :thumbsup: :thumbsup: I must have a look as it will be behind the steering column so access must be tight at best :headbang:
Post by Leslie » Fri Aug 28, 2026 12:56 pm
I had a look this morn , compressor clutch is cutting in and fan starts soon after so that would indicate its not low in gas, the larger pipe into the condenser radiaor is roasting and the other is cool so the compressor has to be compressing .The evap core temp though is 25c so it aint seeing any gas .
Looking at you.pics above x5sport it looks like those are enginebay pics so if that is the case the expansion valve should be easy enough to access just above and behing the engine.There is no info I can find anywhere of anybody changing this part :headbang:
Post by X5Sport » Fri Aug 28, 2026 2:13 pm
That might be because of needing to handle the gas carefully? Both gas and oil are unfriendly to human life I suspect. The TIS says it’s only to be done by ‘authorised personnel’ and when the car is connected to their evac/refill station and the diagnostic system. That might be diyers pause for thought, hence no one owning up to doing it. Either that or they don’t fail very often.
Post by Leslie » Fri Aug 28, 2026 3:04 pm
Ive got.it booked in for a look next friday so hopefully we will make some progress then , he did agree if the compressor is running it cant be low on gas and it has uv dye in it from last regas in April for easy leak checking.
Yes letting the gas out yourself is dangerous as well as bad for the environment :thumbsup: plus if you leave it empty any time you must replace the dryer too.
Post by X5Sport » Fri Aug 28, 2026 4:53 pm
I’m assuming the expansion valve is some kind of pressure controlled mechanical device as there are no electrical connections?
If the system is getting cold but the expansion unit not, then like you, I would be suspecting something being stuck closed.
Post by Leslie » Fri Aug 28, 2026 5:25 pm
I don't understand how it works or what regulates it either but its a cheap part so there can't be much to it ! It must work with some differential temperature change from the in and out pipes , as you say there is nothing electrical to it (thankfully or it would be 400 not 40 quid :rofl: )
edit looks like Bmw would need about 200 quid for it anyway :o
Post by Leslie » Fri Sep 04, 2026 6:02 pm
Well apparently it was a bit low on gas despite the compressor running and I have a small leak at the front condenser ,spotted due to uv dye in the system , it working again now ( left side only :headbang: ) so I will need a condenser , they don't look expensive and a bonus is they are easily accessed with only the fan needing removed. :thumbsup:
I'm beginning to think that antifog sensor has something to do with the right side having no aircon now as its already had a heater valve which made no difference :headbang:
Post by Leslie » Wed Sep 09, 2026 4:11 pm
Well its lasted till today lol (since last friday :rofl: ) , the evap goes to 3c only if you put the fan to minimum , once you increase the fan evap climbs rapidly to about 12c so its either low on gas again ( still never cooled right side when topped up fully) or the evaporator isn't getting the gas as I originally thought , its going back in for a condenser once it arrives. :headbang: I just dunno what's happening ! Apart from looking at evap temp diagnostics about as much use as chocolate fireguard :rofl:
Post by Leslie » Thu Sep 24, 2026 5:31 pm
Condenser fitted to cure the small leak , Aircon still feeble and nothing on right side at all cooling wise , so expansion valve changed out and guess what its all working mint now would freeze the windscreen :rofl: The expansion valve does indeed live on the bulkhead in the engine bay just behind the 2 pipes . I had to tell the mechanic where it was as well as diagnose it :rofl: and use the above pics cheers x5sport
So in hindsight if you have no cooling to the right side vents ( but not hot air which is the heater control valve in the passenger inner wing) and poorish cooling to left vents and the compressor clutch is cutting in and the pipe from the compressor is hot showing the compressor is definitely compressing it could well be the expansion valve.
This was quite tricky to diagnose, no codes to follow and everything "appeared" to be working and didn't make any sense as the evaporator is a single piece not 2 pieces so why it only cools on the left didn't make sense especially when software told me the evaporator was at the correct 3c. The hissing behind the dash was a clue though that the evaporator was being starved of gas and had no cooling capacity and as it got worse the fan going on brought the temp up to 12c in the evaporator in a few seconds , it had no cooling capacity as the gas wasn't getting though in any quantity.
I suspect on a full gas charge a small amount of gas could be forced past the expansion valve restriction so it worked on one side for a short time.
I have also replaced the fogging sensor on the windscreen to get rid of that code but it had nothing to do with the actual problem just a red herring. There is virtually no info on this out there that I could find.£150 for that little sensor cost about 2 quid to make :fuelfire: Condenser was £130 non genuine (mayle) and £30 for an nrf expansion valve inc o rings and about a tenner for 2 genuine condenser o rings , not counting the heater valve at 100 quid (plus regas and labour) which was probably faulty as I was getting heat out right vents no matter what , these all didn't fail at once and my aircon hadn't worked in 18 months or so hard to tell .
Glad its now working but it was a bloody pain :headbang: and I hope this is of use to somebody out there :thumbsup:
Post by X5Sport » Fri Sep 25, 2026 9:33 am
What a palava! I suppose without an electrical connection(?) the car’s brain had no idea of the fault condition so no error code.
At least you’ve fixed it - just in time for the colder weather! :)
Post by Leslie » Fri Sep 25, 2026 10:50 am
Yes true about winter but I'm glad its sorted at last ,hopefully it will stay sorted long enough for a hot spell :rofl: I think the take is if the compressor clutch is cutting in but its not cooling it ain't that low on gas and should be working , this confused the mechanic at the start as low gas the pressure switch would shut the system down to protect the compressor .
It just goes to show diagnostics has its limitations especially when you have multiple faults that have happened over an extended period of time and not everything has a code and old fashioned problem solving still has its place and in my opinion being a mechanic is one of the toughest most stressful jobs out there if you are actually diagnosing faults rather than just changing oil etc. I've not met a mechanic yet working for himself who isn't stressed out !
Post by X5Sport » Fri Sep 25, 2026 12:18 pm
I’m not sure that I’d want to be a mechanic working in modern cars at all! Not only due you need a computing degree but so many repairs need special tools (especially around engine timing on multi-cam/multi-valve power plants), but the workshop manuals are on line, behind paywalls, or out of date.
Then add the EV future into the mix! I mean those come with voltages high enough to make your eyes light up! You have to know where all the safety switchgear is, along with the procedure that must be followed in order not to brick the car, and then they put all this under the bonnet….
This is the plumbing for the climate system that also cools/heats the battery and charge unit (big silver block) and has a heat pump and electric AC compressor (black lump at the front) all connected via special valves and a birds nest of pipes!
Post by Leslie » Fri Sep 25, 2026 1:09 pm
They just wont be cost effective to fix as everything has to go main dealer so they will be scrapped way before they should most mechanics now will just not make the move to electric cars , any I know over a certain age dont want to know.
We have reached the age of the disposable white good car with a built in life expectancy.The batteries every body worriies about will be fine but its all the other non warrantied gubbins it needs to work will fail. :headbang:
The right to fix your own car is gone with everything behind a paywall where out of warranty isn't a option.
