Just started getting turbo boost noises this week when easing off throttle or turning off engine.
And they are getting louder!
I do recall I was getting howling owl noises on a cold start up prior to this.
Is it a knackered turbo? Or a leak somewhere?
2010 E70 X5 - Turbo Boost Noises
A leak in a hose be the first thing I’d check. It’s your cheapest option too.
Turbos going tend to sound a bit like an air raid siren with their whine as they spool up first thing and look for oil leaks as boost will be leaking if the pipe is leaking usually at the joins where o ring seals are worn and often at the intercooler ends .
Sm[]key
https://photos.app.goo.gl/PRX4n5u18yWkxjwM8
Can't figure out where its coming from, will try a smoke test.
Egr cooler metal pipe ok ?
