Battery voltage concerns?
GT456!
Post by GT456! » Sun Mar 08, 2026 3:11 pm
Using the X3s hidden menu...
Cold morning start the battery @ idle is: 11.4
While driving battery reading is: 11.9
The battery is H8 AGM
X3 e83 m54b30 223k on the clock.
Should I be concerned with this battery if it goes with me on a long trips
Post by X5Sport » Sun Mar 08, 2026 3:55 pm
That sounds too low. AGM charging voltage is 14.4V and that it what you should see at the jumper points under the bonnet as well as on the battery terminals themselves. Worth sticking a multimeter on the terminals to see what the alternator is doing. If the battery is more than 5-6 years old then it’s likely approaching (or at) end of life.
The table below is one I found many years ago for checking AGM Battery state of health:
AGM Battery State of Charge (SOC) Table
For greatest life the AGM battery should not be discharged to less than 50% SOC
SOC must be measured off-load, car asleep, at least 3 hours after last use or since last connected to a charger.
100% SOC 12.8 volts or greater - NEW Battery
90% SOC 12.7 volts VERY GOOD Battery
80% SOC 12.6 volts GOOD Battery
70% SOC 12.50 volts Low Battery - Recharge
60% SOC 12.30 volts VERY LOW Battery - Recharge
50% SOC 12.20 volts DISCHARGE LIMIT/or EOL Battery, consider replacement.
40% SOC 12.00 volts Consider replacement if no recovery after charging.
30% SOC 11.80 volts as above - at least one cell dying.
20% SOC 11.70 volts as above - at least one cell dying.
10% SOC 11.50 volts as above - at least one cell u/s
0% SOC 10.50 volts as above - dead/probably non-recoverable.
If the SOC does not hold at greater than 80% after charging and being left for several hours then the battery is most like approaching its end of life (EOL) and replacement should be planned for. If it drops back to 50% or less then the battery’s service life is very limited meaning regular, or daily, charging may be required. 40% and below is usually not worth trying to recover and the service life is complete. At least one cell will be failing or failed.
To measure after three hours, leave the bonnet open/lowered but not latched and lock the car. That way you won’t wake the car when you unlock to open the bonnet.
Post by Leslie » Sun Mar 08, 2026 7:59 pm
Put a meter across the battery jump points to measure voltage when its idling ,if its not around 14v the alternator isn't doing its job / or battery is faulty . Do it before starting and you should definitely see a rise .
GT456!
Post by GT456! » Sun Mar 08, 2026 8:17 pm
Excellent info and resources.
💥For greatest life the AGM battery should not be discharged to less than 50% SOC
SOC must be measured off-load, car asleep, at least 3 hours after last use or since last connected to a charger.😮
However, the battery powers up everytime every first start👍
Thanks Guys!
Post by X5Sport » Sun Mar 08, 2026 9:16 pm
The on board electronics will probably work down to around 10V (for a short period) as the volt drop when the starter engages would cause issues otherwise. A good battery should not drop that far anyway. It sounds as if it still has some life in it though.
I’m never sure how accurate the in board hidden menus are for this, hence putting a meter on the jumper points will prove one way or the other.
GT456!
Post by GT456! » Sun Mar 08, 2026 9:34 pm
Yeah your absolutely right.
With my previous battery while on a cross town journey...the battery began to fade...the radio went, then the interior fan went headlights just before I stopped only the fog lights were on. I experienced this while driving...I was somewhat impressed with BMWs safety processes in such an older car.
Post by Alan Gunn » Mon Mar 09, 2026 6:33 am
Would have expected higher voltage with the engine running so check the alternator out before spending.
You-tube will show you the best way to do it on the alternator itself.
GT456!
Post by GT456! » Mon Mar 09, 2026 6:54 am
Good point...thanks for the reply.
It would be interesting to see what the voltage is for the battery when the car is running...An indication of the health of the alternator.
I'll add in the morning.
GT456!
Post by GT456! » Mon Mar 09, 2026 8:09 pm
💥So at beginning (engine off) 11.6
With engine parked at idel 13.8
Post by X5Sport » Mon Mar 09, 2026 9:10 pm
That’s better. 13.8V is ‘normal’ for a ‘wet’ chemistry battery. 14.4V for AGM. The voltage might come up at a fast idle, or the alternator is set for a wet battery. AGM will still charge, but not fully. 11.6V is not a good sign unless the car is awake and therefore drawing power. The alternator looks good anyway.
Was the off reading after several hours - or at least with the car asleep? I think that generation electronics are similar to the E53 X5 which if memory serves, went to sleep at 16 minutes. 16 being something to do with a countdown timer in the car’s brain.
Post by Leslie » Tue Mar 10, 2026 1:05 am
I changed my last battery due to a similar issue, under 12v when off , the radio would go off almost as soon as car turned off but would still start it no problem.
It was however incorrectly programmed for an agm but had a normal battery fitted so the car sensed voltage was too low and turned things off.
Post by Alan Gunn » Tue Mar 10, 2026 5:39 am
New battery time i think.
After changing it just out of interest check if that 13.8v has gone up a tad i think it will as it won't be fighting to charge a failed battery.
But i could well be wrong.
Check Tayna batteries out for a price they have never let me down and had one for the wife's 120d 2 weeks ago delivered next day as normal on the standard delivery rate.
GT456!
Post by GT456! » Tue Mar 10, 2026 8:26 am
Yeah I would agree a new battery is in the near future for me however, I'd like to get to next winter before I spring for a new AGM.
The neighbor gave the battery to me a bit before COVID. Battery sticker indicates 2016!
This was my first AGM So I do some reading/investigating...turns out these type batteries can stand about 500 charge cycles.
I buy a charger off Amazon. The thing is auto shut off and can detect standard (Lead) or Glass Mat battery. It gives a slow charge when needed.
Tell me when does the average consumer cycle a battery?
That charger has given that battery new life after a couple of cycles. I charge it at the start of every month!
It's only when I understand about the BMWs hidden menu and the voltage check feature that my concerns rise about the battery.
GT456!
Post by GT456! » Tue Mar 10, 2026 8:38 am
/quote]
💥Research tells me this should best be done 3 hours after car goes to sleep yes, 16mins after shut off.
Post by X5Sport » Tue Mar 10, 2026 4:58 pm
I have one car in semi-permanent storage and it is left connected to a CTEK MXS5.0 conditioner charger when not in use. CTEK are the same company that BMW ‘rebadge’ and offer from their Parts teams. They aren’t cheap, but seem to do really well.
My X6 is not in regular use, and I use a larger CTEK on that approx monthly (like you) to make sure it gets a proper charge.
10 years for an AGM Battery is excellent. I don’t think I’ve ever got beyond 6-7 years. One thing AGM really don’t like is being allowed to go flat. That shortens their service life significantly!
