E70 3.0D cutting out
OnlineLeslie
Oh and don't disconnect the battery and close the boot as it wont open again , had to crawl in through back seats and the full width boot board is almost impossible to get an arm around to the post
OnlineLeslie
Got this back together today (injector 5 replaced ) after waiting for the bush for the manifold to arrive , the top one arrived quickly but the red rubber one took ages. Done 20 miles tonight and seems ok though only a matter of time till no 6 fails i guess as its out of resistance spec . I also pulled of the wing and swapped out the rear washer pump and now it works and the tank doesn't drain over the street any more . of course the 2 captive nuts in the wing were rotten and the squire clip siezed to it and spun round and damaged the mount
New squire clips on but one of the bolts that screw into the tank down the door pillar is a complete nightmare to get aligned and started. One of my headlamp washer rams sticks out and I tried to push it in /out and pulled the jet off
It has clipped back in but they don't seem very secure
While I had the gearbox cover off I noticed the transfer box steel cradle is bloody rotten too so it needs replaced for mot
oh and the tail light in the boot led is bust a while and of course you can only sort that with a new light
Old cars are a pain although this is the newest car I own
also when i was putting it up on car ramps I have little assistor ramps for low cars that attach to the first rung of the ramp I used these to stop the ramps sliding forwards as the concrete was sloping downhill but guess what they are not rated for nose heavy x5 it seems as one bent like a banana as soon as the front wheel got on it
- Greydog
A test of resilience
Still as one of my sons said " that car is keeping you fit and bendy" not sure myself some days I walk like C3PO
But in my opinion compared to the E53's the E70 is a step backwards in accessibility for just about everything and every part.
At least your up and running and changing out No6 will be so much faster now you have practised
Got the rear Rose bush's to do soon (starting to creak) and like you there seems to be a lot more rust under an E70 than the E53 4.6is. Or as a comparison my wife's Subaru Outback 3.0 2004 vintage and now with 145k on the clock has required nothing but tyres and brakes serviced annually before MOT (by me) Suspension bushes were changed to PTFE in 2005 when I fitted a full Perrin engine upgrade. It isn't driven hard but it has been faultless it's last MOT 1 advisory track rod rubber bushes cracking
BMW it seems lost something in the late 2000's
OnlineLeslie
Im sure I will be faster the next time , i have a sofa cushion I put on the front brace befind the front panel and surf the engine to get to the back bolts now but as we know you drop anything its gone forever into the abiyss..There is a cable held to the back of the manifold with a male torx that must be removed but you can only feel for it plus the manifold will only come up so far unless you unplug the rail pressure sensor which is probaly how the rear bush was knocked loose .
I think the corrosion has a lot to do wirh mileage too im at 174k now plus I live near a river so salt is always there .my 330d was rotten to hell by 200k falling to bits as well.
The Subaru is hilding up well caring ownership no doubt played a part
That transfer box brace is folded on the tube and sealer uaed to cover the gaps insead of a closed section , its guaranteed to fail once the sealer starts lifting.
Struggled to get out of bed today I really dunno how mechanics do it day in day out , but iI kniow why mine is so stressed all the time working on mainly older cars where everything is siezed ,breaks off or snaps and then delays the job untill more bits are sourced which can take ages.It aint so easy like the haynes said it would be
I reset injectors adaptions kast night , 5 replaced is now at -1.85 and 6 is in the danger zone at +3.2 , it was zero before 5 was replaced I think [max is 4] so I may now get much use out of it after all.
My sos alarm on startup is now permanent it seems which is annoying
The SOS alarm is a code reset according to the manual. Read out and delete. The code will be generated by the telephone control unit.
I’m not sure if the 3G switch off is affecting as the system should be clever enough to look for a 2G signal if it can’t find a 3G one.
OnlineLeslie
Thanks x5sport codes now cleared in telemetrics unit so we shall see
was bloody annoying that every startup
OnlineLeslie
Well it took quite a while to get the transfer box brace changed as without a lift its going to be very tricky with clearance so that was done and it sat about and I bought it home tonight for mot . On the way home and 2nd drive in a month and "engine management light" first time I've ever seen it in 7 years , no real loss of power and "low oil" flashed up . I've never seen this either in 7 years and until now its used a cup full every 10,000 miles and never needed topped up so checked the oil and its half way between min and max on the real dipstick so i stuck a litre in after mot . Also the engine cover foam has turned to dust and is falling out so threw in in the bin , shatters when touched !
A Half mile from mot it cut out and coasted to a halt
hazards on and got it going again( codes checked "low oil" again and "cylinder 456 activation" and in for mot ,some faffing in there as the brake roller on my lane failed but there are 6 lanes so he took it to another lane , it passed and I added the oil and drove 15 mile and its been fine , no more injector codes but clearly its going to brake down again soon
I did turn it off to plug code reader in so maybe missed an injector 6 code ?
Also On tight turns out of junctions I can now hear what sounds like the sound an lsd diff would make dragging its clutch plates , clearly that isn't what it is and there is no other diff noise, tyre all matched etc maybe its a caliper ,maybe its been there a while and I had the windows down as its hot so now hear it as the aircon is broke
but id sure like to know if there is yet more trouble ahead before throwing any more injector monies at it and it close 500 quid to just get there this time.
The joys of aging high mileage cars
3500 miles in the last year
I’ve had ‘low oil’ warnings before and it’s the level sensor failing.
Be careful using the dipstick rather than the idrive level or you can overfill the engine. It’s certainly a ‘caution’ with the N57 engine but the M57 may not be as much trouble.
It was the M57 equipped E53 that threw the low oil warning a week after delivery and again a month later. Two new sensors and it stopped. Bad batch was my guess, but that was a sign of things to come with my Xmas 2004 build X5. On the plus side, like yours, it just didn’t use oil.
OnlineLeslie
I've always only used the dipstick during oil changes since I got it , using the level sensor on the i drive for possibly the 2nd time ever tonight and you are probably right it could well be on the way out after 174k but it showed all green after a litre of oil ,not sure what it was before I added the oil but I'm sure that's not what shut the engine down though more an amber warning at best
OnlineLeslie
Well I recon the knocking on moving off is the prop centre bearing so will have a look but it cutout on the way home again tonight
" 4.5 and 6 injector activation" again and smooth running controller this time I just want it to say injector 6
I'm going to have to take a gamble and change it as the car is as much use a a chocolate fireguard at the minute
OnlineLeslie
Got injector 6 swapped out today ,all now ohm at 180k ohm and smooth running test looks good . 3 of the rubber bushes in the manifold popped out upon removal but I got them all.
Strangely injector 6 clamp nuts were almost hand tight and the injector body was covered in black gunge due to the copper washer leaking.It took a bit more effort with the slide hammer , 30 blows this time but easy enough , you have to take the wiper link off to get enough access for the injector puller. 3.5 hrs it took me today , took about 12 days last time with waiting for parts .
The leak off caps can be gently levered up using a wide flathead screwdriver on the nut for nearest high pressure line to bottom of cap as if you pull by the top only the cap detaches without lifting the piece you want but clips back in again.
I hope this it fixed now and the foxwell scanner has paid for itself again coding the injectors and fault clearing .
50 mile done with some full throttle which is when it tended to cutout.
- Greydog
Top man, not loosing anything into the Abyss at the back of the engine always going to be a plus
Your times are improving now the awkward 2 are done any others will be a breeze
Now mine needs Rose Joints doing and a rear ride height sensor changing
OnlineLeslie
Rrally hope thats all the injectors needed for a while
There is always something needs doing , prop centre bearing next week plus hope the aircon only needs a regas to work again
I've missed driving the x5 but if I hadnt 2 cars id be walking a lot as they seem to take it in turns to break .
Sm[]key
Cylinder 5 injector port is where rain water collects if everything above it isn't sealed. Caused me no end of bother!
OnlineLeslie
The plastic cover that sits over 5 and 6 thd 2 recessed holes were full of rust so there was water dripping down but here was no evidence of rust around the injectors at all. I did think of covering those 2 holes with some high temp tape as tbey are a design flaw holding water which will slowly get down round the injectors past the 2 allen screws which were very rotten in my case.Sm[]key wrote: Wed Sep 03, 2025 11:06 pm Cylinder 5 injector port is where rain water collects if everything above it isn't sealed. Caused me no end of bother!
Leaving it unused for several months hasnt helped in my case .I replaced all 3 of the windscreen cowl plastics though as they fell apart when removed so were letting water down and sealed the joins from centre one to either side one in the middle.I guess the foam over the injectors holds water too, regular driving will boil that off.
