I'm going to change front and rear diff oils in my 3.0d F15.
I have ordered a 500ml bottle of each. Is this enough?
Andy
Differential oil
Differential oil
The TIS doesn’t give the actual capacities but lists 500ml bottles (plural) as being needed, but not how many.
It also says the fill and drain plugs must be replaced, do not reuse.
OnlineLeslie
Differential oil
Nearer a litre each afaik , my e70 rear took near a litre
andy_b
Differential oil
Yes, I see that now, so why the f*ck they sell 500ml bottles I will never know.
Differential oil
It’s worse on the X6 (E71) as it has a special torque distribution rear diff with two different oils in three chambers that absolutely must not get mixed up. The outer chambers have electrically driven clutch packs that need their own special (aka expensive) oil. 500ml isn’t quite enough!
