E70 ride height warning
Greydog
Post by Greydog » Thu Jun 26, 2025 5:04 pm
OK
Just looking at realoem
This is the parts list that goes with the drawing attached yesterday the sensors are labelled Item 1 to the left and item 7 to the right. Take note of Item 7 Vehicles with self levelling suspension 2 off but all levelling sensor part Numbers are the same
I hope it makes more sense now
No. Description Supp. Qty From Up To Part Number Price Notes
i For vehicles with Xenon Light
S522A=Yes
01 Level sensor 1 37146853754
For vehicles with Chassis & suspens. setup "Adaptive Drive"
S2VAA=Yes
01 Level sensor 2 37146853754
02 Bracket, level sensor front 1 37146773135 $14.25
S2VAA=Yes
02 Bracket, level sensor front 2 37146773135 $14.25
03 Fillister-head screw M5X10-8.8-ZNNIV 4 07119904303 $0.25
S2VAA=Yes
03 Fillister-head screw M5X10-8.8-ZNNIV 8 07119904303 $0.25
04 Regulating rod 80.4MM 1 37146776549 $15.33
S2VAA=Yes
04 Regulating rod 80.4MM 2 37146776549 $15.33
05 Self-locking hex nut M6 ZNNIV SI 4 07147575163 $0.25
S2VAA=Yes
05 Self-locking hex nut M6 ZNNIV SI 8 07147575163 $0.25
06 Hex bolt M6X16-8.8-ZNS3 1 07119904371 $0.16
S2VAA=Yes
06 Hex bolt M6X16-8.8-ZNS3 2 07119904371 $0.16
07 Level sensor 1 37146853753
or
Self-levelling suspension
S2VAA=Yes
S220A=Yes
07 Level sensor 2 37146853753
08 Left ride height sensor bracket 1 37146871399
or
S2VAA=Yes
S220A=Yes
08 Right ride height sensor bracket 1 37146871400
09 Hex bolt M6X12-8.8-ZNS3 1 07119905827 $0.38
or
S2VAA=Yes
S220A=Yes
09 Hex bolt M6X12-8.8-ZNS3 2 07119905827 $0.38
10 Regulating rod 71,5MM 1 37146752797 $6.18
or
S2VAA=Yes
S220A=Yes
10 Regulating rod 71,5MM 2 37146752797 $6.18
11 Universal socket housing uncoded 6 POL. 1 61138383300 $3.47
only in conjunction with
-- Contact bushing MQS ELA with cable 0,35-0,5 MM² AG 3 61130056961
-- Dummy grommet MQS Ø=3,6 3 61138366249 $0.20
12 Universal socket housing uncoded 6 POL. 1 61138383300 $3.47
Post by Leslie » Thu Jun 26, 2025 5:43 pm
Id get a look under there first see if its the wiring is bodged or the actual sensor is faulty or the little link arms have come off.
Post by sapphireblack » Thu Jun 26, 2025 6:14 pm
The wiring on both is apparently bodged from a recent health check report.
And the plot thickens. Without doubting any input here i wondered what genuine parts might cost. That stirred the situation at the dealership somewhat, as my car was apparently showing as a US spec. OK, so we know they are built there, but the steering wheel is on the right side in my car, which they have had in the workshop only recently.
Anyway, after a hiatus, i just got this via email. It shows different part numbers per side, so i am even more confused.
We have finally found them! I had to pull in the parts manager from Tunbridge Wells too and he was stumped as well.
The part number you gave me is correct but I wanted to confirm that they are correct for your car.
37146853753 - £84.89 + vat
37146853754 - £78.37 + vat
Both are available to order 2 day lead time.
Post by sapphireblack » Thu Jun 26, 2025 7:52 pm
I wish i was more hands on. Looking back on the heath check report, it mentions bodged wiring as i mentioned above, it doesnt condemn the sensors.
Maybe i need a good wiring man more than new sensors! 🤔
Post by Leslie » Thu Jun 26, 2025 8:28 pm
The front left sensor is probably for xenons mine has adaptive xenons and has a left front sensor . Depending on whats actually wrong with the wiring a used plug with some wire to reattach is maybe the best way forward and get it soldered in.
looking at realoem 754 part is a front and 753 is a pair of rears , the left of which has a bracket possibly the right doesn't need a bracket , my car isnt at home to check as its broke at the minute :rofl: You can see number 2 is a front bracket and the operating arm is at right angles where the rear is parallel , that will likely be the only difference between a front and rear but they wont be interchangeable .See below
https://www.realoem.com/bmw/enUS/showpa ... 7146853753
Post by sapphireblack » Thu Jun 26, 2025 8:53 pm
I appreciate the continued guidance. I can't lift the rear end of the car on ramps as I don't possess any, and knees are no longer conducive to handling wheels on/off without some difficulty, if i can avoid it.
I know an auto electricians near enough to visit. They have a full lift and can get underneath it. I think I'll start there before buying any parts on spec. It could just need a wiring tidy up?
If ...753 is a paired set up even the dealership has got it wrong.
Post by Leslie » Thu Jun 26, 2025 8:59 pm
They probably assumed yours had xenons as most cars had :thumbsup: the 754 shows for adaptive drive and 753 for adaptive drive or self levelling suspension so its a bit confusing really :? but part 2 the bracket is shown for front and linked to 754 so I can only assume its the front sensor .
An auto electrician sounds like just the man for the job .
Post by sapphireblack » Fri Jun 27, 2025 8:18 am
Well the car does have air suspension but not very much else. Halogen headlights and manual folding door mirrors.
It is poverty spec for sure and a totally different animal to my E71.
From what is easily determined, the car was built March 2009 but it was only first registered September 1st 2009. Clearly, it's not a customer vehicle order.
Post by Leslie » Fri Jun 27, 2025 9:06 am
I have auto folding mirrors and given the width of it them are needed for parking , its definately poverty spec lol maybe a company purchase that had to be under a certain cost.
Post by X5Sport » Fri Jun 27, 2025 9:12 am
It might have been ordered just as the financial crash of 2008 happened, got cancelled and reduced to minimum spec. Dealer probably still had to take it.
Post by sapphireblack » Fri Jun 27, 2025 9:20 am
X5Sport wrote: Fri Jun 27, 2025 9:12 am It might have been ordered just as the financial crash of 2008 happened, got cancelled and reduced to minimum spec. Dealer probably still had to take it.
All plausible i don't doubt.
So the auto electricians i know actually declined to get involved its a BMW But they did refer me to an ex techie who i have spoken to and seems to know the issue.
I'm waiting on a call back to tell me when to bring it to him.
I don't regret buying this car just yet, but it ceased being a budget vehicle a while ago. It is still better suited to a life in Greece than the 'mint' E71 so ill keep cracking on for now.
Post by sapphireblack » Thu Jul 10, 2025 2:27 pm
As noted in another thread. I had the wiring and plugs repair kit ordered in readiness.
The wiring was apparently OK but both plugs weren't. One disintegrated on contact, the other was barely hanging on. The plugs have been replaced now. The left sensor and arm are buggered and are to be replaced next week
Hopefully this matter will conclude a week today.
Post by sapphireblack » Thu Jul 17, 2025 4:30 pm
So today was hopefully the last day of expense on the budget E70..
The broken and cable tied left rear ride height sensor was replaced, complete with a new arm. My newly found Indy workshop even took the main bracket off, stripped it and painted it all voluntarily. Excellent service. A main dealer would do nothing or simply suggest replacing it
It was also the day for sorting the headlight washers. Long story short, both jet/arm, thingies were broken, but i was curious why no water had appeared under the car. I found out why this morning. The main feed pipe from the tank supplies both washers but it had been fully detached, folded and cable tied, and cable tied out of sight. It took some finding but all is now working properly again. I think this car was maintained by bodget and leggit. Truly appalling lash ups to avoid spending any money on it. Its come at a cost to me but the issues it had, not all of which i was aware of are all remedied. Its a feel good factor, even if the wallet has taken a hit.
A new perplexing query regarding the build spec also arose. To test the headlight washers, lights had to be on of course. When Chris switched the lights on i noticed them self leveling as Xenons would. 🤔 Unless self levelling is a standard feature, there is little doubt in my mind now, this car was to be built with Xenons, but for reasons i will likely never know, they were deleted.
Regardless, it's a little bonus that this feature exists. I may treat it (me really) to some LED H7s and have it as good or better than Xenons 🤔🤫
Post by X5Sport » Thu Jul 17, 2025 5:08 pm
If it didn’t have self-levelling there would be a headlight aim control thumb wheel on the light switch in addition to the instrument lights dimmer.
Post by sapphireblack » Thu Jul 17, 2025 5:42 pm
X5Sport wrote: Thu Jul 17, 2025 5:08 pm If it didn’t have self-levelling there would be a headlight aim control thumb wheel on the light switch in addition to the instrument lights dimmer.
It has that too !
