Good afternoon
My steering column won’t adjust.
All fuses are in tact I believe.
Could it be the switch on the column??
Electric steering column not working
No it's probably the seat module ifyou have memory function
+1 on the above.
Do the memory buttons work for the seats.
If you need a module the range rover uses the exact same part and on that auction site we all know they go for a lot less money.
- Xman
It can be the switch, they do fail sometimes. If there is no sound from the motor at all, it might be the switch or the motor itself.
