Crank no start
Crank no start
Post by Themoog2 » Sun Oct 20, 2024 7:02 pm
Two days ago the wife moved the X5 (01 4.4i) from our driveway to the neighbour for photos of the house to be taken , then she put it back.
Today I go to start it and it runs really rough for maybe 5- 10 seconds then cut out. It will not restart but turns over.
I’ve noticed that I can’t hear the fuel pump running so I lifted the rear seat and put my multimeter across the 2 fat wires going to the connector. No reading when ignition is on but there is 12v across the two slimmer wires on the connector.
Fuel pump fuse is ok.
Am I looking in the right direction or am I doing something wrong? Granted it was blowing a gale and raining a bit too so I wasn’t fully committed..
Crank no start
Post by X5Sport » Sun Oct 20, 2024 8:14 pm
Just a thought. Check the fuel pump relay. You’ll need to drop the glovebox and then the fuse board above it as the relay is on the back.
The image below is from the LHD model, but having had exactly this on our E53 I know where it is. The relay is about £10 (or was a few years back). Have a look at Realoem to get the part number. It’s not an unknown issue. If it fails then the fuel pump won’t run.
Realoem has this page: https://www.realoem.com/bmw/enUS/showpa ... Id=61_4036
Part is common across multiple BMWs and all E53s. It’s light green from memory.
When mine went it cost over £200 in diagnostics to find a £10 part. The Indy went looking for all sorts of other things before the relay was identified as gone bad. I wasn’t impressed…..and stopped using them altogether shortly after (they’ve since gone bust anyway). My wife had taken the car to Wales and had to come back in a 1.0L Corsa with a speed limiter (hire car). She wasn’t impressed either!!
Might not be this, but for the sake of a few quid and use of a screwdriver, well worth eliminating.
Crank no start
Post by Leslie » Sun Oct 20, 2024 10:48 pm
I think 2 very short moves and turned back off might have something to do with it and its maybe flooded itself/fouled the plugs :driving:
Crank no start
Post by Themoog2 » Mon Oct 21, 2024 8:39 pm
I found a YouTube video by 50skid and he runs through complete diagnostics of the E53 fuel pump. Something that concerns me tho is when I turn it over it doesn’t make that ‘ugh ugh ugh ugh’ sound - it’s much smoother like a turbine. Almost like there is no compression.. Saying that, I have never heard my engine just turning over as it’s always started first and every time in the 10 years I’ve had it.
I’ve checked the timing chain and it’s tight not floppy in the oil filler hole.
When I get the motivation I’ll do a proper diagnosis and hope it’s not something serious..
Crank no start
Post by marti » Tue Oct 22, 2024 5:40 pm
If its anything like the e38 V8....a short move will flood it....so what you do is....(battery fully charged)..put throttle flat to the floor, turn key to crank and dont let it go!...dont pump the pedal!...flat to floor...keep the key at crank position...dont stop....eventually it will start to fire...keep it going dont let the key go and foot to the floor until it fires on all pots and loads of smoke out the rear :) ....dont ask me how I know :D
Crank no start
Post by Themoog2 » Tue Oct 22, 2024 10:07 pm
Ah the two short drives to next door then back. I didn't even think about that.
I've got the back seat up now anyway so may as well carry on..
Crank no start
Post by Leslie » Tue Oct 22, 2024 10:09 pm
Themoog2 wrote: Tue Oct 22, 2024 10:07 pm Ah the two short drives to next door then back. I didn't even think about that.
Just as well I mentioned it 2 days ago then lol :rofl: :rofl: :rofl:
Crank no start
Post by henrym3 » Wed Oct 23, 2024 3:34 pm
Diagnostics if you’ve got it, might be a sensor. If not pull a plug see if it’s wet and check for spark.
Crank no start
Post by Themoog2 » Wed Oct 23, 2024 5:44 pm
Who said 2 short runs flooded it..
Turned the key with my foot flat down and just let it crank. Eventually it popped and spluttered back to life with a smoky exhaust.
I've left it running for 1/2 hour to let it sort itself out.
Looks like the wife flooded it. Better chain her back to the kitchen sink for safety.
Thanks for the ideas chaps 👍
Crank no start
Post by Leslie » Wed Oct 23, 2024 5:57 pm
:thumbsup:
Crank no start
Post by X5Sport » Wed Oct 23, 2024 7:10 pm
It was the ‘no fuel pump’ bit that made me think relay. Every day’s a school day. I’d not have considered something as simple as flooding. Duly noted.
Crank no start
Post by Themoog2 » Wed Oct 23, 2024 10:26 pm
Yes but why would it flood? Surely bmw wouldn’t design an engine that you can’t run for say a minute or two then it won’t start a few days later..
Crank no start
Post by X5Sport » Thu Oct 24, 2024 8:03 am
Hence me not thinking about flooding. I thought the injection systems these days had something within that prevented flooding due to overfuelling. I believe there’s something about ‘cold running’ mode that replaces the good old choke we used to have, but the fine detail of its operation I can’t find. I suppose if the plugs get ‘wet’ then the engine stops playing.
The main thing being that you’re up a running again……and without breaking the bank. That has to be a positive for any BMW owner.
Crank no start
Post by Leslie » Thu Oct 24, 2024 2:26 pm
The colder damper climate here may need a more rich fuel mixture on startup than usual , the unlikely situation of 2 cold starts and not going more than a few yards possibly combined with the previous runs not getting fully warm/slow low rev town running to clean the plugs has all come together to beat you. Its one of those situations that was more common in days gone by with carbs etc . (i'm only guessing here ) :thumbsup: If there turns out to be an actual fault you will know soon enough and when was the air filter last changed in case its adding to the problem but I'm sure you keep on top of stuff like that :D
Crank no start
Post by Themoog2 » Fri Oct 25, 2024 4:03 am
Hmm..
You know what - I haven't changed the air filter or spark plugs for a while.. 2015 when the timing chain was done. Guilty as charged.
In my defence it's only done about 30k miles since then and has always started first time and ran sweetly.
I actually have a brand new set of plugs in the garage that I've had for a while. Maybe an engine service is due..
I have changed the oil and filter 3 times since then so don't go to hard on me :(
