Gas pedal non-responsive
GT456!
Post by GT456! » Sun Jul 07, 2024 12:58 pm
Changed out ccv, reinstalled the air intake and now I have engine surge and dead acceleration. Replaced...gas pedal and the throttle m54b30 high mileage X3. 06. But a TANK when on the roadway!
Any help needed.
Post by X5Sport » Sun Jul 07, 2024 1:07 pm
Air leak? Any split hoses?
What error codes are showing?
GT456!
Post by GT456! » Sun Jul 07, 2024 5:27 pm
2786 throttle-valve potentiometer 1 and 2
Post by X5Sport » Mon Jul 08, 2024 5:26 pm
That error code covers a number of issues. Did you inadvertently move any wiring, or even not plug something in (it wouldn’t be the first time one of us has done that)? Check from the throttle valve back into the ECU for continuity.
GT456!
Post by GT456! » Mon Jul 08, 2024 7:16 pm
Yeah, I went over my work almost at the point of removing the air intake.
Then I discovered that throttle and pedal can be misaligned which can call for a recalibration/adaptation.
GT456!
Post by GT456! » Wed Jul 10, 2024 12:48 pm
Newtis says 📢...
Note:
A faulty throttle valve adjusts the adaptation values stored in the DME control unit. These adaptation values need to be reset after replacing the throttle body.
Delete adaptation value:
Connect DIS Tester
Select vehicle type
Select "Digital Motor Electronics MS43", carry out brief vehicle test
Continue by pressing bottom right arrow
The "Fault pattern selection" window appears.
Select the "Function selection" (bottom left)
The "Function and component selection" window appears:
Select ”Service functions”
Select "drive"
Select "Digital Motor Electronics"
Select "Reset adaptations"
Select "Test plan" (bottom left)
The "Test plan" window appears. Select "Reset adaptations"
Further procedures according to DIS instructions.
After the first engine start, the new adaptation values are set in the DME control unit.
Post by X5Sport » Wed Jul 10, 2024 8:36 pm
Very handy….but you probably wished you’d known that before cursing up a storm!
GT456!
Post by GT456! » Thu Jul 25, 2024 7:55 pm
Had a little time to run a Foxwell scan.
I can get the car started soundly. But the idel is horrible! Engine
keeps trying at constantly attempting to get the right idel...up and down, up and down. Still uncontrollable.
Now the scanner yields, (see pics)
D35b
2786
2787
Post by X5Sport » Thu Jul 25, 2024 8:43 pm
D35b is a DSC error with a sensor.
2786/2787 looks like a throttle sensor or potentiometer issue
Have you had a look at bmwfault.codes as a reference site? Might help you a bit.
GT456!
Post by GT456! » Mon Nov 11, 2024 9:08 am
Yesterday I removed the air intake...I saw nothing ripped,tore or out of the ordinary.
Think I'll replace cold crank cyclone valve ..I don't know! :x
GT456!
Post by GT456! » Sun Sep 28, 2025 10:33 am
I've had time to give the 06 some attention. Focused on the air intake. Looks as though I didn't replace the 16mm nut that secures the air intake to the engine block. Now to find the time to put Humpty back together again 😭
