Car jumps on full turn
Dave willow
Hi when we have to put the steering on full lock it seems like the car jumps ,you can feeling through the steering wheel, We have all terrain tyres on the car ,had the front wheels tracking done because had a new control arm fitted .any ideas please.
The times I’ve seen this on here have always related to tyre choice. BMW xDrive cars are very sensitive to tyres and some can give rise to major issues including broken diffs or transfer boxes.
There was one several years back fitted with General Grabber (I think) and required a new front differential. Tyres were the cause as the rolling diameters weren’t matched. The outer diameter must be less than 2mm difference between any wheels and axle set.
It isn’t always the case, but over the years members have reported issues that go away as soon as the right tyres are fitted. The giveaway is almost always apparent as uneven movement in either direction at full lock and walking pace.
Other causes may be poor oil condition in the diffs. BMW say they are lifetime oils. As owners we know better!
Approved tyres are all marked with a
on the sidewall. You’re looking at Michelin, Dunlop, Continental, Bridgestone, Pirelli type (aka expensive) brands.
Dave willow
Thanks for the reply, only had the car 3months .Bought the car with general grabbers on so now I now what the problem may be . Only 12 more issues to sort out
thanks again .
Wonder how the last owner was using it to have those tyres on
sounds like its been used as a proper land rover
Lobster Pot
I had all these problems last year when I bought mine changed the tyres had transfer box reset nothing helped ended up having a new transfer box so prepare for the worst expect a huge bill and hopefully you may get a surprise and it’s not gone as far as the worst caseDave willow wrote: Wed Dec 06, 2023 9:04 am Thanks for the reply, only had the car 3months .Bought the car with general grabbers on so now I now what the problem may be . Only 12 more issues to sort outthanks again .
