Last Autumn my X6 was put through the MOT with no issues found or advisories issued.
A week later it had work done by a main dealer that included a ‘Safety Inspection’, something that they do every time a car goes in. That found an Amber issue with the front right suspension. Amber meaning it isn’t yet urgent but should be done within a couple of months. Unsurprisingly I was a bit suspicious (like many I don’t trust the motor industry generally) and money was tight so I took a chance and left it.
A few days back (roughly 9 months later) the X6 went in for an oil service plus fuel filter and recall for front airbags. A safety inspection was carried out at the same time. Funnily enough no issues were found with the car at all.
So, was it an attempt to add value, or just a technician’s view that another technician didn’t seem to be concerned about? If it was that bad I would have expected a main dealer who carried out the MOT (same Dealer) to find it then (given they were a week apart!).
‘Adding Value’ at service!
A vertu dealership by any chance?
I had this a few times with daughters Skoda at a Bristol Street motors (vertu) dealership, so won’t use any of that group any more.
Mot failed was told it needed new suspension arms as bushes worn at about £200 a side, when I questioned it and said what about just changing bushes, we can’t do that sir it has to be new assemblies m, but when I told them car had Skoda Mot failure insurance, they miraculously just changed the bushes at billed Skoda for about £20 a sideplus a bit of labour! Then there was, it needs a new battery as the test shows it’s failing, that will be £180 please said no thanks, I’ll look into it, two years later battery still fine!
And finally after annual service, advised rear brakes need a service, that will be £180 sir, said I’ll leave it for now. I got a local garage to check it out, they removed wheels and drums, checked, cleaned, adjusted and reassembled for substantially less, but said they didn’t really need doing!
Needless to say we won’t be going back the that dealership.
Wasn’t one of those dealers but have experienced the same with Škoda and changed dealers as a result.
Its no surprise dealer trust is low
- jaynana
I’ve had the same Merc dealer giving me a scare about a fault in a similar ‘inspection’ which I decided to ignore, and the same dealer to NOT issue such warnings in later years. And the
is still fine
Trust no one and we're off to a better start.
I have similar history, though not pertaining to the X6. I was suckered into two lower suspension arms on my Touareg at an MOT three years ago. The same place a year later tried the exact same scam. Not the most inteligent of MOT/repair centres. I declined
- StuBeeDoo
I don't use $tealerships, for anything other than parts, unless I absolutely have to - ie recalls.
When my F25 was in for its first EGR cooler recall, I got a 'phone call saying "Your car needs new tyres", but no explanation as to why. I didn't take them up on the offer, because I knew that the tread depths were all 3.5-4.25mm and the tyres were all in condition commensurate with their age. When I got the "health check sheet", hand-written on the bottom was "NON APPROVED TYRES!!"
They actually were *-marked tyres, Pirelli Sottozeros (it was the end of January) in the correct size, load, and speed ratings for the car. I double-checked the tread depths, and they were exactly what I remembered them to be from the week before the car went in.
The next EGR cooler recall, there was no mention of anything untoward on the health check - in spite of the car having non-approved tyres by that point.
Funnily enough a National MOT company played that game with my wife’s E46 on its second test. It was checked elsewhere and no fault found. They were finally replaced last year when the year was 16.sapphireblack wrote: Sat Sep 09, 2023 7:45 pm I was suckered into two lower suspension arms on my Touareg at an MOT three years ago. The same place a year later tried the exact same scam. Not the most inteligent of MOT/repair centres. I declined
