Engine cuts out
Engine cuts out
Hi all
Any ideas every time I boot the car now the engine cuts out I have to stop take key out put it back in and it starts first time and it starts first time
Does come up with injectors 3/46 ? But clear it and it’s fine ???
Engine cuts out
You’re going to need the error codes scanned in order to narrow it down to what the car isn’t happy about.
Could be a damaged wire to the injectors, either on one of the connector plugs (look for corrosion) or the connector not fully home. Losing three suddenly is unusual and points at something else, hence needing the error codes.
No sign of fuel leaks, or a strong smell of fuel (or smoke) on first start? I’m just wondering whether the pressure is dropping in the fuel rail due to something like an injector leak (need to do a ‘leak-off’ test to check for an injector nor sealing between power strokes).
No warning messages around injection other than ‘injectors 3/46’ (which I can’t find anything for so could be a typo?).
Engine cuts out
A smotth running test or as said a leak off test would tell you about how good your injectors are. The trouble with common rail is one bad one tends to effect the pressure going to the others.
- marti
Engine cuts out
Sounds like the piezo is on its way out...happended on my X6, kept doing the same as yours is...new injector required Im afraid.
Engine cuts out
The code I get now is 0042FB
Description:
Injectors bank 2, control
I have done an ohms test injector 1,2,3,4,6, are 183-184 and injector 5 is 120-140 so I take it this could be the problem?
Description:
- marti
Engine cuts out
That seems to be your problem.....are you using a generic scanner as a BMW designated one will tell you which number injector is bad....but looks like No5.....most of the time its 5 or 6
Engine cuts out
I am using the Carly scanner but I am looking into changing this as the injector will need coding anyone got ideas for a good scanner / coder ?
Engine cuts out
I had an injector fall on me was running really rough. It happened at the worst time, I couldn't complain though as I had 190k miles on clock and im assuming it only happened due to using asda fuel.
Engine cuts out
Why blame Asda fuel? I think its a total myth its inferior. The various supermarkets don't have their own refineries so they source it from "the market".H4MP wrote: Mon Jun 12, 2023 1:25 am I had an injector fall on me was running really rough. It happened at the worst time, I couldn't complain though as I had 190k miles on clock and im assuming it only happened due to using asda fuel.
Engine cuts out
Its just they have a higher proportion of biodiesel, and less additives.
Engine cuts out
Myth or no myth when my hpfp went the company who tested it said the filters was clogged and traces of metal filings and it had failed mainly due to cheap supermarket fuel so vpower only for me now I’d use bp ultimate aswell but none local to me
Engine cuts out
The rear 2 injectors ( 5 and 6) are susceptible to filling with water around them if the cowel at the back either side above the master cylinder on drivers side splits which is very common .Mine was cemetery split and I could only get a new one at about 120 quid ,
: still cheaper than injectors though
I'm sure Carl can do a smooth running test to pinpoint the correct faulty one so I'd want to do that first and expect it to be a right pain to remove if water has got in .
