While doing my scans I have the fault.
LSZ/LCM (light switching centre)
Dimmer Potentiometer Wire Open.
Are we talking about the dimmer for the instrument cluster lights?
It works and is just a small irritant that a fault is listed that a spray of contact cleaner might fix.
As always replies are appreciated.
Faults
Faults
Almost certainly the cluster dimmer thumbwheel by the light switch.
You can try contact cleaner (as it’s the simplest) however a lot of these modern parts use carbon tracks rather than copper windings and it’s just possible the carbon layer is wearing out or has cracked. That would cause it to show as open circuit. Hopefully it’s just dust.
Can’t say I recall ever seeing a comment about this issue on any BMW forums (I know I spend too much time surfing them….
