Glow plug module
Lobster Pot
Glow plug module
Hi guys can anyone help me locate glow plug module I can’t seem to find/see it it’s a 2011 40d
Glow plug module
Pre-heating control module is below the air intake plenum - which needs to be removed first.
To change the module, remove electrical connectors (1) and then undo the two screws holding it in place (2)
Has the module failed or the glowplugs (or both)? Previous bitter experience advises any glowplug change to also include the preheat controller module as these usually fail weeks after glowplugs get changed.
The module is usually made by BERU.
The intake plenum is the big yellow thing below, with the module where ‘7’ is. That’s the tightening sequence for the plenum itself. Quite a lot of stuff has to come off unless you can get to it from below. I’ve got a feeling the alternator is in the way as well. It’s been a while since I looked, but I remember changing the oil filter needed care to avoid metal tools touching live wires!
Lobster Pot
Glow plug module
Hi thanks for that yeah looks like module has failed as I’m not getting regens and I’ve got linbus code this is last option to see if I can rescue dpf before I have it gutted and remapped
Glow plug module
Removing your DPF (if that’s what you plan) could lead to bigger issues. MOT Testers know how to find that and will fail your car.
Lobster Pot
Glow plug module
If done properly it’s impossible to tell as they not allowed to remove anything to check my 5 series before it was wrote off was done already done when I bought it flew through every mot with flying colours and never smoked one bit
Glow plug module
5 of my heater plugs are out and my dpf still regens so I don't think that is your issue, 4 have been out last 3 plus years (2009 x5sd)
Is it getting up to temp as that is critical should be over 80c.
Lobster Pot
Glow plug module
Temps are fine runs between 90 and 100 until the linbus code disappears it will never regen hens why I was looking at changing module it’s in next week for a gearbox service and all other fluids so I’ll book it in to be done
