I'll skip the boring preceeding threads on the winter wheels subject..
Managed to confuse myself somewhat and in need of opinions. By fitting a 10" wheel on the rear I will add 15mm spacers to compensate, I'll then need longer bolts. Standard threads are 37mm I think? What length extended bolts should I be shopping for, 37 +15 or other, and would anyone reuse the 37mm locking bolt, wing it, or buy a set of four extended and waste two, or just buy 10 x extended bolts and forfeit the locking bolts?
New wheel bolts query
Onlinesapphireblack
- marti
Yours math is correct 37+ 15, I would buy the locking nuts, but thats up to you.....
Onlinesapphireblack
Thanks.
I've seen some 50mm bolts, I'm guessing 2mm short isn't crucial.
- marti
I wouldnt have thought so.....sapphireblack wrote: Sat Oct 29, 2022 4:55 pm Thanks.
Onlinesapphireblack
FWIW 'official' recommendations are 45mm bolts when using 15mm spacers
- marti
