U joint and centre bearing
Thesisqokid
Hi all, iv noticed one of the u joints on the prop has play so im thinking do both and the centre bearing, now how do i take the centre bearing off as there is no nut on the u part to take that off to access bearing
- StuBeeDoo
If it's anything like the E46, the bearing is pressed-on to the propshaft.
Are the UJs replaceable? I can't see separate parts listed on BMWFans. I suspect it might be a job for a propshaft specialist, or try to source a good secondhand shaft.
Thesisqokid
I cant see any circlips on u joints but just watched a vid on you tube regarding centre bearing and the fron half of the prop seperates allowing access to bearing
- StuBeeDoo
It does, but the bearing still has to be pressed on and off.Thesisqokid wrote: Mon Sep 05, 2022 4:15 pm the fron half of the prop seperates allowing access to bearing
- GT456!
It's known that they are not replaceable. But I did find a shop that did that intricate spot welding...he's retired now.StuBeeDoo wrote: Mon Sep 05, 2022 3:45 pm If it's anything like the E46, the bearing is pressed-on to the propshaft.
There's your answer! Or you could try eBay or Amazon...I'm in the same boat.
I've also gone to the bone yard myself.
