BMWx3 EGR code p0401
wizard-58
wizard-58
Have you for the BMW error code as P1286 is a generic and unknown in the code list here:
https://bmwfault.codes/
There are multiple references elsewhere to a fuel/air ratio error. That could be related to the MAF.
wizard-58
ok thank you for that Im going to plug in my laptop and see if inpa can give me a better or more acurate code ..i was sort of expecting a code for the swirl flaps ...they were removed before i got the car but the control unit and the vacum pump was left on ..i removed the vacum pump and blocked off vac pipe but left the control unit fitted as ive heard that needs to be mapped out ...so maybe the code is just telling me the pump isnt opperating ??? if its the pump then ill fit an extended vac hose to the control unit and just mount the pump out of the way for now to test and see rather than refitting .
wizard-58
well no luck here cant get inpa to work ..ive checked all the settings ( comm port 1) all the usual stuff says the lead is connected but nothing maybe a dodgy lead god knows its worked before ..any way Ive got torgue pro as well but that just gives me the 1286 code so no nearer to sussing it out . maybe a new lead but im getting to the stage where i keep buying stuff and getting no-where .
wizard-58
okey another up date ..code p1286 on bmw x3 2.0d e83 = 41E2 exhaust gas recirculation actuator control when useing INPA ..which im guessing is the egr solinoid which i did replace so im going to swap the new one for the old one and see what i get .fingers crossed again .
wizard-58
well cured p1286 but now got the 4501 code back
wizard-58
below is the fault as per INPA in german and translated to english but where i go from here is floating in the ether because ive not got a clue any more seem to be going round in circles .
abgasrueckfucher-regelung,regelabweichung. abgasruckfuhrung bank 1 zugeringer durchssatz erkant
exhaust gas recirculation control, control deviation. exhaust gas recirculation bank 1 low throughput detected.
luftmasse zu hoch/negative regellabweichung testbedingungen nochnichterfullt fehlermomentun vorhanden und bereitsgespeichert fehler wurde das aufleuchten einer warnlampeverursachen
air mass too high/negative control deviation test conditions not yet met error present and already saved error would cause a warning lamp to light up
Umweltsatz (enviromental sentance )
1 mileage 254344 km 2 mileage 254344
engine speed 855.06 1/min 882.64 1/min
coolant 50.12 c 67.19 c
rail pressure 370.22 bar 362.34 bar
injection quantity 13.00mg/hub 9.06 mg/hub
airmass per cylinder 567.14mg/hub 560.84 mg/hub
boost pressure 1073.23 mbar 1083.08 mbar
pedal sensor 0.00% 0.00%
duty ratio exhaust
feedback controller 89.80% 89.80%
duty cycle boost
pressure controller 94.52% 94.52%
Ambiant pressure 1014.15% 1014.15%
any body got any ideas before i finally just give up and have the whole lot mapped out or scrap the car ..
duty ratio exhaust
duty cycle boost
Onlinesapphireblack
Take it to a specialist indy dealer, got to be worth investing in a full pro scan now.
- marti
4501 relates to exhaust gas recirculation....EGR, MAP, MAF......you did say the MAP sensor you replaced was generic...if its from china then I would punt on that. You shouldnt have had that black smoke when you put your foot down....unless there's no DPF present.
wizard-58
Glad you’ve got there at last. I think more than a few of us have inadvertently caused other issues accidentally and ended up chasing our own tails. I know I have!
wizard-58
Hi everyone Just to update ..the car has now done a few miles since i did the work includeing 820 mile trip to okehampton in dartmoor .and back no problems at all .in all the problem has cost me about £300 in parts ..and proberbly about 50+ hrs of labour .but christ only knows what that would equate to if id taken it to BMW ..Maybe they would have solved it quicker and less parts .but even if it had taken them 5 hrs to solve it still would of cost alot more in £££s ..It did give me head ache for a while but Im feeling alot better about the whole experiance and a bit of self pride .now for the MOT
Fantastic effort and you’ve every right to be chuffed with yourself. I would be too
You could probably add at least another ‘0’ before the decimal point and one or two digits up from ‘3’ for BMW working on the car. Around here main dealer prices are well north of £200/hr +VAT with Indies around £100/hr inc VAT.
Never anthropomorphise computers. They hate that.- marti
Excellent work and determination,well done
