EGR Fault
EGR Fault
See above. Did they disturb or incorrectly route some wiring, or leave plugs disconnected. Has wiring got damaged, pins broken etc? There’s a lot of sensor wiring all round that area.
Eminem0473
EGR Fault
Yeah I noticed the diagrams you posted thanks. Didn't realise that the sensors registering faults were actually on the dpf that they had removed. Do you think these sensors could have caused the other fault codes that were stored aswell.
EGR Fault
You have certainly had a rough time with it
, it would have been cheaper by now to go to Bmw but with a gutted DPF the first thing they will say is you need a new one which will be a silly cost . It was running ok till it wouldn't start after the dpf was gutted is that correct ? If so its likely there is a separate fault now or it has been intermittent but there all along and is getting worse. If the dpf has been coded out the other codes for oxygen sensor etc may not be relevant now anyway.
The only thing that looks important now is rail pressure which is often a pump/injector leakoff issue which can be tested with software.
The turbos etc are all controlled by rubber vacuum lines these can get brittle and split id disturbed causing all sorts of issues and there are a lot of them ,many hidden from view and I suspect but am not sure that egr is also monitored by the airflow/airmass meter as less air is needed when egr is occurring. These are complicated beasts when they go wrong .There are lots of videos on utube for the 35d as it was imported to America but I don't think they got the 40d so that isn't well covered for faults.
Eminem0473
EGR Fault
Thanks for your reply. I have had issues since it first broke down due to the turbos. After getting it back from the garage it kept throwing the eml light and showing egr faults. After a couple of hundred miles it broke down again and the garage fitted a new egr valve and glow plug module. After they where fitted the car then threw the fault codes for glow plugs 1 and 4. It also kept coming up with the same egr fault codes so the garage fitted another egr valve. Unfortunately the car still kept throwing the eml light for egr faults. So I decided to go down the route of dpf and egr delete. Now after 6 days using the car I now have the issues and fault codes as stated. Rough cost of repairs at the moment is about £5000
Eminem0473
EGR Fault
I can remember once that a scan showed up something about smooth running in cylinder 6. Do you think that could have anything to do with problems I've experienced? Thanks
EGR Fault
You are right about this there are water trays at the back of the engine and they split and drip water on injectors 5 and 6 , I looked at mine just this week and the drivers one is split and will be letting water in , until you touch them they look fine but they are just sitting there and wobble when touched .This in mine the piece with the build date on it , looks fine but its actually broken in 2 .The centre one is the most critical and they get brittle with age.marti wrote: Sat Mar 19, 2022 9:45 am Can you see any evidence of water ingress around at the rear of the engine around injector 5 & 6?
EGR Fault
It could certainly have something to do with the non starting due to excessive leak off lowering the injector rail pressure ,if the min pressure is not met it will refuse to start . The fact yours started later when some pressure may have build from a start a while before just made it meet the min pressure so it started. Battery condition is critical too as a higher starter speed will allow a greater injection pressure to buildEminem0473 wrote: Sat Mar 19, 2022 12:35 am I can remember once that a scan showed up something about smooth running in cylinder 6. Do you think that could have anything to do with problems I've experienced? Thanks
Eminem0473
EGR Fault
Will try and get the garage to look at this when it goes in to get the o2 sensor and exhaust temp sensor replaced. Although the garage have said that these 2 faulty sensors wouldn't have been the reason my broke down on me.
EGR Fault
You really want to find out why it broke down and if it's an injector issue first so you can get some reliable miles on your car without spending any more money you don't have too
Get them to do a smooth running test with their scantool and see if any are out of spec and go from there . It broke down again and you need them to find out why
otherwise it is only going to happen again
I don't think changing sensors which may well be fine on a part that doesn't even work anymore is going to help much .
Eminem0473
EGR Fault
Thanks for your reply. So is the o2 sensor and the exhaust temperature sender not needed on my car anymore since the dpf was deleted? I noticed a couple of weeks ago when the car was started from cold that smoke came from around the area where the turbos are. I got my daughter to video it today when I started the car but don't seem to be able to attach the video on here.
EGR Fault
Videos require an external link rather than uploading. The site owner doesn’t permit video uploading.
You shouldn’t be getting smoke from anywhere. That implies an exhaust gas leak or oil leak.
And with the DPF missing (illegal) you have no need for the sensors because the emissions controls are no longer installed and they were coded out.
EGR Fault
The sensors should now not be needed as said and there shouldn't be an exhaust leak really, I assume it does away as soon as it starts if so id stick with the main plan for now to get a running reliable car as if you give the garage too many jobs the one important one will be less likely to be completed.
Eminem0473
EGR Fault
Yeah the smoke from the turbo area goes away after a couple of seconds from startup thanks
- lezmtaylor
EGR Fault
Ye gods, what a tale of woes !! I really feel for you, I have a 2002 4.4 l petrol/lpg and am really pleased I don't get the problems that some diesel cars throw.
I have just changed my spark plugs and that took me best part of 30 hours !! thank ye gods won't need doing for at least another 60,000 miles, or realistically the life of the car ( have done less than 400 miles each year over last 3 years). or me as I'm 79 in May.
Lez
Lez
