2010 E70 X5 3.0d - Fault Code DSC 5EC0 - Steering Angle Sensor
Sm[]key
Post by Sm[]key » Thu Jul 15, 2021 8:57 pm
Hi All!
After sorting my 4x4 light fault by replacing all the abs sensors, the 4x4 light comes up now about every 20 miles.
If I turn off the engine the fault resets.
Plugged it into INPA and got the following fault code DSC 5EC0 - Steering Angle Sensor.
I'm getting the bearing hub replaced soon (humming noise at around 30 mph), so hopefully it will be resolved, when I jack the front end up the front wheel has a bit of movement.
The question I have is would a failing front wheel bearing throw this fault up?
Post by Leslie » Thu Jul 15, 2021 10:16 pm
An ABS sensor failing would throw up a code for that wheel , it sounds like you need an actual steering angle sensor rather than an abs sensor . The movement at the hub is more likely to be worn arms than bearing play although the bearing is droning and needs replaced , mine was the same new bearing cured the noise but no fault codes were there for that .
Try clearing codes and see what comes back first could be an old code ?
Sm[]key
Post by Sm[]key » Thu Jul 15, 2021 10:25 pm
All the ABS sensors are new, month or 2 old.
Clearing codes does not change fault reoccurring....
Post by Alan Gunn » Fri Jul 16, 2021 7:00 am
Steering Angle Sensor could be failing as said above.
Sm[]key
Post by Sm[]key » Sun Jul 18, 2021 10:30 pm
Has anyone changed this themselves? Can't find a guide to do it? :D
Post by Leslie » Mon Jul 19, 2021 11:50 am
Not done but think it needs calibrated after.
Post by henrym3 » Mon Jul 19, 2021 3:08 pm
Put in BMW X5 e70 steering angle sensor replacement in google. Loads of vids.
Sm[]key
Post by Sm[]key » Mon Jul 19, 2021 5:49 pm
I did, non for e70.
Post by X5Sport » Mon Jul 19, 2021 8:48 pm
Post by henrym3 » Mon Jul 19, 2021 9:01 pm
Sm[]key
Post by Sm[]key » Sun Jul 25, 2021 12:03 pm
https://www.ebay.co.uk/itm/324723634506 ... Sw2Zxg-Wui
Thinking of getting a 2nd hand one off eBay, as the 4x4 light coming on all the time in now and is annoying me!
Any pointers to stop this going horribly wrong? :driving:
Post by sapphireblack » Mon Jul 26, 2021 5:26 am
It looks pretty straightforward to replace, but if not confident maybe buy the used* part and seek professional help with a BMW indy or other trusted workshop,
* what mileage was on the donor car? You dont want another failure a short time down the line.
Post by henrym3 » Tue Jul 27, 2021 7:27 pm
My e53 experience warns me that this could be the ABS module. It never seems to give fault codes but blames everything else. ie wheel sensors, sas g/b etc. Unfortunately one has to follow the fault code but don’t be surprised if the fault returns after sas repair. Hope the sas fixes it.
Sm[]key
Post by Sm[]key » Sun Aug 01, 2021 9:09 am
Ok thanks all, I've received the second hand cluster unit will install later in the week.
Does anyone know if these need to be coded to the ECU?
Post by Alan Gunn » Mon Aug 02, 2021 6:32 am
Yes i would think so if changing the cluster.
Tamper dot on mileage plus the miles.
