Getting the transfer box oil changed due to the usual start of transfer box vibrations so going cheapest option first.
What oil do people use and how much is needed to change it. Does it need a replacement top up / drain bolt?
I have read one forum that suggests BMW use a different oil in the transfer box if you ask them to change it die to vibrations. Is it true and if so what do they use?
Thank you
