WANTED X5 E70 20" Rear Alloy
Sm[]key
Post by Sm[]key » Sat Feb 06, 2021 4:12 pm
X5 E70 20" Rear Alloy wanted.
The wheel is the 10 spoke double 'V' type.
approved
Re: Wanted: X5 E70 20" Rear Alloy
Post by approved » Sat Feb 06, 2021 4:25 pm
I think the wheel you are looking for is the 227m, and finding a rear one that is still round and undamaged is a struggle.
I cracked one on my first e70 and it was repaired under warranty as the wheel was still perfectly round. My second one had a wheel replaced, I think as part of the AUC check when i bought it. Ive also cracked a front one, which had a dent too, which couldn't be repaired as the dent was too close to the crack, so i got one off eBay, refurbished and uncracked but it was still expensive from memory.
Good rears are generally 500 quid a piece upwards
They can repair ( most second hand ones on eBay are either needing refurb or refurbed with repairs)
Depending on whats wrong with it, you can get yours fixed for about 100 quid (maybe less) but rears are well known for cracking due to the sheer width.
Your two other options is to go 223m which is the 19" sport wheel. Slightly better ride, less prone to cracking and less expensive. You could buy a full set and sell your wheels to cover the cost. You could also go 333m which is the 20" facelift wheel, which apparently doesnt crack as bad as the 227m and you can use your existing tyres, but they can corrode badly as they are machined on the face...
Good luck.
sid10
Post by sid10 » Sat Feb 06, 2021 6:05 pm
Hi can you post a picture as I have a X5M alloy wheel 20" that was refurbished as new but never used as I went down the 21" route ?
Post by sapphireblack » Sat Feb 06, 2021 6:51 pm
Sm[]key
Post by Sm[]key » Sat Feb 06, 2021 7:10 pm
Yes
Post by sapphireblack » Sat Feb 06, 2021 7:45 pm
That one no good? Refurbished at that price is pretty good imo.
Haggle using the blemishes as a bargaining point.
Sm[]key
Post by Sm[]key » Sat Feb 06, 2021 9:06 pm
Already seen it. Would of been perfect, as I wanted to collect today, but would only post....
Re: Wa7 nted: X5 E70 20" Rear Alloy
Post by sapphireblack » Sun Feb 07, 2021 12:52 pm
The time lost searching for an alternative surely makes buying the one identified, and having it sent easier and quicker :wink:
Post by sapphireblack » Sun Feb 07, 2021 1:05 pm
https://www.ebay.co.uk/itm/293977290633
This one is collection only
Sm[]key
Post by Sm[]key » Wed Feb 10, 2021 5:28 am
Thanks for the help guys!
I managed to pick up a full set of almost perfect wheels off gumtree on Sunday.
These had been in storage from less than a years use, not one crack to be seen!
BMW quoted £800 for a new one..
Post by sapphireblack » Wed Feb 10, 2021 10:19 pm
What style, not 227s again?
