Battery
Olliefrom83
Battery
Afternoon
Can anyone recommend a brand of battery for my 2011 30d? Believe it to be a 019
The battery in the car is struggling now, it’s a bmw battery, not sure if it’s original, but now on a near daily basis keep getting the battery discharge warning, along with some battery related warnings coming up, checking with scanner, all are low voltage related.
I have a ctek conditioner, but battery never seems to get back to where it should be.
Ollie
Ollie
Re: Battery
I’ve got a Yuasa YBX 9019 AGM battery on mine. Bought via Tayna Batteries. Next day delivery and a 5 year warranty.
Olliefrom83
Re: Battery
I was just on Tanya website, reasonable prices, your is the 40d? So should be suitable for mine, I just looked at it again and it’s an agm 90ah 900a 900cca
Re: Battery
Very good people at Tayna very helpful and honest guy's.
First time i went there they lent me a battery while they tested the new battery i had bought elsewhere online.
They did a report on the faulty battery for me to send to the online seller to get my money back.
Then sold me the exact same (good) battery and for a better price and no charge for the report.
Bought several batteries from them since.
Olliefrom83
Re: Battery
Thanks Alan
That’s good to hear, I have ordered the Yuasa YBX9019 AGM, after hearing the reviews hopefully that will do the job.
Ollie
Ollie
Re: Battery
Remember to code the battery to the car
S3RYK
Re: Battery
I'm panicking now you mention 'coding the battery to the car', I'm just about to order the same battery for my 40d, but what's the coding piece you mention?
Re: Battery
Car needs to know it is a new battery so the IBS system charges it correctly.S3RYK wrote: Fri Feb 05, 2021 10:33 pm I'm panicking now you mention 'coding the battery to the car', I'm just about to order the same battery for my 40d, but what's the coding piece you mention?
Unless your car is an older e53 then i don't think it needs coding.
Re: Battery
After the E53 BMWs are fitted with an Intelligent Battery System. This adapts the charging as the battery ages and needs to be reset whenever a new battery is fitted. All Dealers can do it as can places like Halfrauds. It should be done as soon as possible after a battery change in order to avoid undercharging or over charging. It’s a quick job (5 mins) and just involves ‘telling’ the car the battery type and capacity via the OBD2 port.
My last car from Skôda also had this system fitted and it is becoming more widely used generally as part of emissions controls (only run the alternator at the required rate so less engine load hence less emissions - or so I’m led to believe).
S3RYK
Re: Battery
-New battery fitted on Monday (Bosch AGM), same spec as fitted,
-CTEK charger connected Monday, just to ensure it's fully charged
-25 mile round trip yesterday
-Went to it this afternoon - same warning message as before 'BATTERY' excessive drain from electrical consumers'
Everything is off, no lights left on etc... What could it be? comfort access (that's been playing up for 18 months?
Re: Battery
Was the battery coded to the car? It needs to be or the charging circuit won’t do its job.
If it was then you either have a faulty battery (it does happen) or something is keeping the car awake. If the comfort access has been playing up and preventing the car from going to sleep then that could well be the cause. Finding the issue needs patience and an ammeter. If the car is telling you it’s a consumer circuit then have the error code read (with the right software rather than a generic code reader) should tell you which system is creating the warning as it should show in the error log.
A few years back I had a Road Angel plugged into the glovebox USB supply. It wasn’t causing any overload and turned off with the car, but it was keeping part of the on board systems awake and was logged. Removed it and the issue went away. The dash/iDrive error code was very similar to yours.
libra007
Re: Battery
I ordered from Tayna too, with their battery checker as my car doesnt have start stop so it recommended me a normal instead of AGM, now removed battery was original lasted almost 12 years and checked the part number its showing AGM also in carly it was AGM type too. new battery is non AGM, does it matter? or shall i change it for AGM?
OnlineLeslie
Re: Battery
If iyou get it coded for that non agm battery it will be fine but if you leave it uncoded it will not be fine as probably quickly ruined by overcharging .I believe a like for like you can get away with no coding but not when you change the battery type. ie Agm to ordinary battery.libra007 wrote: Fri May 07, 2021 7:22 pm I ordered from Tayna too, with their battery checker as my car doesnt have start stop so it recommended me a normal instead of AGM, now removed battery was original lasted almost 12 years and checked the part number its showing AGM also in carly it was AGM type too. new battery is non AGM, does it matter? or shall i change it for AGM?
Re: Battery
As you have an E70 you need to get the battery change coded (if not already done). The advantage of the AGM type is that these cars draw significant current to run their on board systems so an AGM is better suited (and was fitted by default) but it’s not essential to have one. The coding is however important as AGM batteries charge at a higher voltage than non-AGM meaning you could overcharge your replacement battery.
@Leslie - you need to recode because the car has the Intelligent Battery System which adjusts the charging as the battery ages. It needs to be told that a new battery is fitted regardless.
libra007
Re: Battery
Yes I did code accordingly, first time find out that it has AGM was the current battery data from carly. There was no AGM mark anywhere on the battery itself, that was the major cause of me believing its a non AGM plus no start stop. Battery barely survived this winter and now was giving daily message for low battery, after a full charge with trickle charge to full, it went to low within a weak even with daily driving.X5Sport wrote: Fri May 07, 2021 7:54 pm As you have an E70 you need to get the battery change coded (if not already done). The advantage of the AGM type is that these cars draw significant current to run their on board systems so an AGM is better suited (and was fitted by default) but it’s not essential to have one. The coding is however important as AGM batteries charge at a higher voltage than non-AGM meaning you could overcharge your replacement battery.
I will give a call to tayna if they replace it for an AGM version.
