Hi Everyone,
Hope someone might point me in the right direction:
I run a 2012 X6 and I have an irritating noise coming from the n/s/f wheel area, It sounds to me very much like a worn wheel bearing type noise.ie da da da da da etc. or even d da, d da, d da, d da etc
Up to press this is what I have had done:
I have so far had the n/s/r wheel bearing changed ,thinking it may be from the rear n/s but no!
I have just had the front n/s wheel bearing changed ,which I do believe seems to have quietened something!
I did take it to a indy BMW garage who believed it was a wheel bearing but didn't know which? They advised me to leave it until it got worse so they could pinpoint which bearing! They said that the had done a test on the transfer box and it was ok ,
I have changed my tyres from 'economy brands' to Pirelli , but alas the noise is still there!!
The sound is not a squeal or thud or bang, and there is nothing felt through the steering wheel? The sound as mentioned is more of a 'da da da da da 'etc, its not really that loud (my wife says she can't hear it !) but whereby the rest of the car is very quiet on the road , this da da da da is doing my head in! Any suggestions? Thanks
2012 X6 N/SF IRRITATING NOISE!
Unclebuck
Re: 2012 X6 N/SF IRRITATING NOISE!
All sorted it was the front differential that was making the noise !
- marti
Unclebuck
By eliminating other things really! I knew it come from the near side, you could feel it under your feet if you were in the passenger seat, I took to an independent garage where they changed the transfer box fluid, I had had fitted 3 new wheel bearings fitted to rear n/s, front n/s and drivers front the Indy thought that it really couldn’t be anything else! After they got me a price of new one fitted £3-4K I decided to buy a second hand one that they fitted! All sorted and they said that the old one did have movement and wear on the diff shaft! It was a gamble but it paid off.
Onlinesapphireblack
A good friend used to say that he often experienced an irritating noise from the NSF, but this only ever happeneed when his wife was with him
