Air suspension
b21playa
Air suspension
Hi all
Noticed nsr was sagging so I've ordered a new bag but when I start car I couldnt hear the compressor run.
Could this just be the fuse blown? Are there any repair kits for the compressor like there was for the E53?
Thanks in advance
Thanks in advance
mr angry
Re: Air suspension
Did you check the old bag was leaking before replacing and have you scanned the car?
b21playa
Re: Air suspension
I’ve ordered new airbag, haven’t changed it yet.
Managed to scan car and got it to raise up. Will see if it stays up, if not change airbag when it turns up
Re: Air suspension
Fuse only blows if there is a big problem its 40 amp now on e70's .My compressor had a dent in the head where something tried to escape lol !
mr angry
Re: Air suspension
What faults were revealed from the scan?
b21playa
Re: Air suspension
Attached
Re: Air suspension
It definitely should not be in Transport Mode. That’s only used when the car is being shipped from the factory to Dealers.
b21playa
Re: Air suspension
It’s weird as I never put it in that, and only 1 side sagged
Re: Air suspension
Just occasionally these cars do this. It can be caused by a flat or dying battery. The computer gets itself in a tizzy and resets to transport mode. Does your tool allow you to make changes? If so then it’s just a function change to turn it off again.
b21playa
Re: Air suspension
I reset the module and the code has gone
