smoke from my 2005 E53 3.0i any advice please
lou9890
Post by lou9890 » Thu Mar 10, 2011 12:33 pm
Hi all
Need some advice Please if anyone can help ive noticed over the last few weeks that im getting a large puff of white smoke coming from the exhaust. this lasts for a couple of seconds and then goes. It isnt effecting the performance and has only happened about 4 times so far, once on morning start up and the rest whilst moving at about 30. I have had the x for about 7 months and it has only got 38k on the clock. i have also taken it to my local indy and they said they could find a problem.
Turks
Contact:
Re: smoke from my 2005 E53 3.0i any advice please
Post by Turks » Thu Mar 10, 2011 1:01 pm
Is this from cold or once the engine is warmed through..?
Turks.
Present:
Past:
bonerp
Post by bonerp » Thu Mar 10, 2011 1:09 pm
check the oil - does it look right?
Might just be the weather making the fumes a little more obvious - like breath on a cold day.
Might also be water though - hence checking the oil - could be gasket problem but you would find oil in water (coolant slick) or water in engine oil - white/creamy around the oil filler cap....
Do you use the car on runs? Could have water collecting in the exhaust too I suppose?
good luck hope its nowt
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
lou9890
Post by lou9890 » Thu Mar 10, 2011 1:27 pm
Thank you for you replies i hope its going to be nothing.
its alot more smoke than the cold weather fumes . ive had an oil change a couple of days ago and said it was ok.
it has happened form cold and when the engine has warmed up
Bonerp i will have to take it out for decent run as most of my journeys are short.
Thanks again
Lou
dan.squires
Post by dan.squires » Thu Mar 10, 2011 1:49 pm
I had this problem on my e46 330, had the milky crud in the filler cap too. So had a panic thinking it was a head gasket but turns out because I was only doing short journeys condensation was building up in the rocker cover and exhaust. Got told to take it for a long drive and check the oil cap again, did that and it all cleared up. After that I used to take it for a long run atleast twice a week to make sure it didnt happen again.
Post by X5Sport » Thu Mar 10, 2011 9:03 pm
If you do find any 'mayonnaise' on the oil cap you really ought to do an oil and filter change, and then get it nice and hot with a decent run. Short runs also kill batteries as they never properly charge up.
