trifecta lights
Loperamide
trifecta lights
Post by Loperamide » Sat Feb 15, 2020 9:16 pm
Sometimes I get the trifecta lights randomly, even when at a stop.
Scanned for codes and got the following:-
mr angry
Re: trifecta lights
Post by mr angry » Sat Feb 15, 2020 9:56 pm
I have had this for ages on e53 and get no codes...i am at a loss as to cause
Re: trifecta lights
Post by X5Sport » Sun Feb 16, 2020 9:55 am
The first one is probably a dirty connection, or waterlogged, or bad sensor on the wheel ABS sensor leading to a drop out which the ABS computer then detects as a signal loss and puts the warning lights on. Check the connections or maybe replace the sensor if the wiring has started to deteriorate at all.
The second one I think is to do with the coolant control for the airflow unit in the intake used to tell the DME how much air is entering the engine. I’m reading MAP in the same way as MAF. Newtis mentions it here.....
https://www.newtis.info/tisv2/a/en/e53- ... ng/X7YlLIm
and here.....
https://www.newtis.info/tisv2/a/en/e53- ... ng/Xw3xhPS
