This X5 N62 has a strange rattle in the top end. My iSoft thingy says Exhaust Camshaft control bank 1 and sometimes Inlet Camshaft control bank 2. When I start it, it is noisy but nothing very definitive until it warms up then all is quiet and smooth until I rev it past about 2800rpm and then as the revs drop in comes the rattle until the idle is reached and all becomes quiet again. When I hold the rpm above 3000 the rattle slowly creeps back into it and it starts to run rough. I have just finished putting new to it cams and valvetronic gear as well as the hydraulic adjusters and levers in it along with head gaskets. Virtually the complete top end has been rebuilt. When I removed the covers to check things I saw that the exhaust cam was lagging and when I put a spanner on it it very easily returned to the normal position so I swapped the VANOS in the exhaust right bank but it made no difference. The oil is definitely getting through to the VANOS unit because all the moly assy lube had been washed away and good clean oil was present.
I am thinking it must be the solenoid controllers but I have cleaned them and checked they operate but cant be sure they are working properly. I cant find anything on Real oem to tell which is ex and in but if I recall correctly the top is in and lower is ex. Before I go ahead and get some new solenoids can anyone shed any more light on this.
I have been playing with this thing for 18 months now and have long since lost my sense of humour but still have a working flame thrower.
Just to add to it I feel that the oil in the VANOS that should hold the cam advanced is draining without the pressure to hold it there.
