BMW X5 e70 bad mpg 2007 30d
Ryanleady
Can anyone help I am only getting 16.5 mpg out off my 3.0d and I am driving it normal not dring it hard I read up I should be getting at least 20 to 25 mpg around town Does anyone have any ideas what it could be or what I can change it has just had a service by the garage I got it from they did only do diesel filter, oil filter and oil change
- Alchemist
Re: BMW X5 e70 bad mpg 2007 30d
has the thermostat been checked? If it's stuck open the engine won't be heating up properly, this caused a drop of 3-4mpg in my E46 3.0D.
You may need software to check though if your X5 doesn't have water temp on the dashboard clocks (as i think none do)
- LincsX5
As Alchemist said probably thermostat. My MPG had dropped off and after some Google’ing I checked the coolant temp on a run and it was low. You can check the temp in the hidden menus (Google it) if you haven’t got diagnostic kit. I changed both thermostats, not a big job, and all was good again. Mine settle at 26.4 mpg using it on a daily 13mile commute across the city.
pcdee
I get 27.1mpg around town.
Definitely get the temp stats checked, if they don't get up to temp it'll affect the DPF regeneration.
Graeme
Just collected my car after heater plug recall. All computers reset to 0. Five mile drive home at 3:30 pm with stop start, traffic lights, roundabouts etc. 18mpg!!!! Car normally does 28 overall and 34 on motorway run. And yes, new thermostat fitted and DPF regenerated a few months ago!
Graeme
Graeme
Jayx5
I've had both of my stats changed about 4 months ago and it's doing 22.2mpg at the moment but its pulled a caravan from essex to dorset but it never gets above 24
Jayx5
