Brake warning light
Lincspoacher
Brake warning light
Sorry Been here before, fitted ned pads front and rear and new sensors front and rear but still got the light on the dash and getting check brake pads warning, is there a reset anywhere?
wpoll
Re: Brake warning light
From memory there is no reset - I just changed the pads and sensors and the message cleared itself.
I'm talking about the text warning on the Check Control display - not the red dash light. If you have a low spec cluster (dash) then the brake warning lamp on the cluster could indicate low brake fluid levels.
