Rear Drive shafts
Wesley1874
Rear Drive shafts
Post by Wesley1874 » Wed Jun 12, 2019 3:02 pm
Hello. I am having a rear drive shaft changed on my 2007 X5. The one that was taken off, I'm told is a bit longer than the one delivered (810mm compared to 840mm). Does anybody know why there is a difference? Could it be to do with the fact it has a factoryfit towbar for some reason, various parts seem to be towing specific? Thanks
Re: Rear Drive shafts
Post by X5Sport » Wed Jun 12, 2019 7:22 pm
Different differential fitted to cars with 3.5T towing limit uplift from 2.7T. It has different length shafts.
Wesley1874
Post by Wesley1874 » Wed Jun 12, 2019 7:38 pm
Sounds feasible..the first owner towed a horsebox. Maybe a couple of horses in a big horsebox is heavier than the caravan we tow. Thanks for that.
Wesley1874
Post by Wesley1874 » Wed Jun 12, 2019 8:07 pm
Option 233, increased towing capacity from 2.7t to 3.5t, available with factory fit towbar.
Thanks for your help!
Post by Leslie » Thu Jun 13, 2019 3:37 pm
I think I read on here the splines are also a different diameter into the diff so It still wouldn't fit even if the right length as The guy bought another diff but it wouldn't fit his car .
