Cruise control question
weirdfish
Post by weirdfish » Tue May 07, 2019 1:23 pm
When I use cruise control and increase the speed via the + button on the steering wheel the car takes off like a rocket, is this right, I would have thought it would just slowly increase until I let go.
Then when I've finished using cruise and simply press the loud pedal the car doesn't like it at all, very hesitant and lumpy.
Car is a 2003 4.6.
Re: Cruise control question
Post by henrym3 » Tue May 07, 2019 8:42 pm
Yes it will as you say "go like a rocket" it’s like when you disengage at 50 go down to 30 then re-engage it goes to 50 flat out. Shouldn’t be hesitant and lumpy when you go to the loud pedal.
hennabm
Post by hennabm » Wed May 08, 2019 12:32 pm
All the BMWs I have had do exactly the same thing:- head for the set speed as quickly as possible.
When I had a Renault many years ago the cruise on that was far more gentle in its acceleration.
weirdfish
Post by weirdfish » Wed May 08, 2019 12:41 pm
That's good to hear.
I'll experiment a bit regarding the lumpy acceleration when in cruise control.
Post by Themoog2 » Sat May 11, 2019 5:04 pm
If you hold down the + side of the cc button the vehicle will accelerate rapidly. To go gently press the button incrementally.
