Air suspension inactive after work
Sirrepairalot
Post by Sirrepairalot » Thu Mar 07, 2019 1:42 pm
Hi folks,after recent work on the back end replacing control arms and bushings,I’m now getting the above.i have been raising the rear axle with my scanner but after about 4 days it starts to lower again.getting code saying regulation time fault 1 sided.all I did was disconnect the 10mm nut on the sensors when removing the trailing arms and all worked before.
Re: Air suspension inactive after work
Post by henrym3 » Thu Mar 07, 2019 3:00 pm
Are you sure you haven’t flipped one of the sensors over, make sure they are both pointing in the same direction.
Post by Alan Gunn » Thu Mar 07, 2019 6:15 pm
As above often done and not noticed.
Suchy1977
Post by Suchy1977 » Sun Mar 10, 2019 10:01 pm
Start with the simple steps first, check the fuse its a 30amp fuse the last one on the right side of the fuse tray i had an issue with my suspension been really rough I checked and it was luckily only a fuse. Hope its same for you. 👍
Sirrepairalot
Post by Sirrepairalot » Wed Mar 13, 2019 1:55 pm
Well defo not a fuse(I wish)😀and Alan I am gonna be checking sensors when I grab 5 mins🙄
