Hello can someone confirm the front jack lifting point on my M50D, is it the circle in-between the 2 x holes as in image?
Many Thanks,
Jack Lift points
JONM50D
Jack Lift points
- gmc15
Re: Jack Lift points
The jacking point for each side is just behind each front wheel and looks like this
https://xdrivers.co.uk/forum/download/f ... iew&id=553
JONM50D
Thanks, I am aware if these, but wish to jack the whole front end up in one go. I beleive there is a front end single jacking point.
From what HenryM3 found (on your other thread about same) it is in the middle of the rectangular area just beyond the circular depression in your image. If you have a circular hard rubber (or similar) pad you can put between the car and jack (safely) that should help.
JONM50D
Many thanks found it, and jacked up car with no problems.
