Hello all,
had the above for almost 5 years and just hit 138,000 mls. Oils, filters etc changed every 7000-8000 mls. The manual gear change is becoming a little sticky, particularly reverse. Obviously will get the gearbox oil checked but it was also suggested I changed the transfer case oil, I'm sure this has never been changed, would anyone recommend doing this?
Could anyone recommend a supplier? I always buy all oils, filters etc from Opie but they can't help.
2006 X3 3.0d manual
Re: 2006 X3 3.0d manual
Both boxes would benefit from new oil.
The transfer box will need a reset afterwards but a good indi will be able to do it all.
rockwell
Thanks Alan, I may as well order diff oil as well. Could I reset using a C110 scanner? Otherwise there's a good diagnostic guy close by.Alan Gunn wrote: Tue Feb 05, 2019 1:00 pm Both boxes would benefit from new oil.
No the c110 can't do the reset.
The foxwell 510 can do it and the iCarsoft BMM V2.0 as well.
