oil temperature sensor?
Loperamide
Post by Loperamide » Sun Dec 16, 2018 2:03 pm
can anyone tell me where this is located on a 2003 4.4i ?
Re: oil temperature sensor?
Post by henrym3 » Sun Dec 16, 2018 5:23 pm
Not aware of an oil temp’ sender, just pressure. Of course could be wrong.
IanP
Post by IanP » Sun Dec 16, 2018 10:26 pm
Is the oil level sensor not combined with the oil temp sensor?.
This should be at the front of the lower oil pain i think.
Post by henrym3 » Mon Dec 17, 2018 10:41 am
It’s not listed as a temperature sensor in the parts, just oil level
Post by henrym3 » Tue Dec 18, 2018 8:42 pm
There must be one somewhere, I was playing with the hidden menu today and it tells you the oil temperature,
Post by X5Sport » Tue Dec 18, 2018 9:26 pm
The only place I can find it It mentioned in the TIS is that appears to be combined with the oil pressure sensor as an all in one.
IanP
Post by IanP » Tue Dec 18, 2018 9:56 pm
https://www.e90post.com/forums/attachme ... 1273973836
I know it's from an e90 but i had thought the sensors were common
Post by henrym3 » Wed Dec 19, 2018 12:01 pm
ome / BMW E53 X5 4.6is SAV /
Search documents:
Installation Location (EBO) B6238, X6238
Installation position B6238, X6238 front left of engine B6238 Oil temperature sensor X6238 Component connector (2-pin, black), Oil temperature sensor ...
Wiring Diagram (SSP) Engine oil temperature sensor
Engine oil temperature sensor X60003 28 X6238 2 X6238 1 X60003 27 . A6000 DME control unit GR/BR 0.5 M_TOEL RT/BL 0.5 A_TOEL . B6238 Oil temperature sensor . A6000 DME control unit 15 31 ...
Been out and searched round that area and can’t find any 2 pin connector that I can’t account for
