Valley pan gasket?
Valley pan gasket?
If you were taking the trouble to replace the gasket, and, or, o-rings in the pipes, ( water leak ), what else would you sort out or replace whilst you had it all apart.
Re: Valley pan gasket?
All of the hard to access small water pipes at the rear of the engine.
OK, what sort of costs are we looking at then, gaskets pipes o-rings etc etc
Are these all main dealer genuine bmw parts or would aftermarket parts be as good
Time wise, how long should this take, approximately of course
- sleepyfolk
Oil separator and all the pipes, yet another winter job for when I do the rocker cover gaskets, timing cover seals and plugs etc etc
