engine fault code 274E help
dazzasgotav8
Post by dazzasgotav8 » Wed Dec 05, 2018 9:33 pm
From time to time on a cold start i will get the amber engine light flash on and off if i leave the car to tick over it goes out and all is fine , some times it will come on and stay on when i check the fault codes it comes up with 274E misfire detection checksum failure with misfires detected on cylinders 2,3,5,6,7,8 , but once its warm it never shows a fault i have looked into this fault code and it seems people talk about coil pack failure , spark plug failure and even chain slipped on pulleys , thing i dont understand is once its been started the fault seems to clear and it drives with no issues should i be thinking about replacing the plugs and coil packs or is there something else that would give this fault ..........
Re: engine fault code 274E help
Post by Horizon » Wed Dec 05, 2018 10:52 pm
From what I've read, several different posts say 02 sensor , would have expected it to be all the misfires on one bank though, not on 6 of the eight cylinders.
Have you got inpa, or a reader that will let you read live data from the 02 Lambda sensors.?
dazzasgotav8
Post by dazzasgotav8 » Thu Dec 06, 2018 7:46 pm
Dont have access to inpa but can get my hands on a snap on reader but every time i check the codes never a mention of a o2 sensor fault , this is why i am confused as people speak of lots of cures for this code but no one seems to agree on what that fix is ..
dazzasgotav8
Post by dazzasgotav8 » Fri Dec 28, 2018 12:42 pm
update on this problem after a bit of research it appears this issue could be linked to the intermediate levers not 100% sure what thats all about so still doing some research into it think this mite have been a recall fault , am keeping my snap on microscan in the car now and have started to keep a log of the fault as and when it happens
Post by henrym3 » Fri Dec 28, 2018 7:39 pm
Some other checks to do would be to check the fuel pressure. Could have a weak pump or a leaking injector. That might be why it happens on start up.
Post by henrym3 » Fri Dec 28, 2018 7:42 pm
To add to that fuel filter if hasn’t been changed
dazzasgotav8
Post by dazzasgotav8 » Fri Dec 28, 2018 7:49 pm
henrym3 wrote: Fri Dec 28, 2018 7:42 pm To add to that fuel filter if hasn’t been changed
fuel filter has been changed with a good quality mahle one , havent got a fuel pressure tester might have to see if i can borrow one
