Hi,
Hi have a 2010 4.0D LCI X5 SE with a strange electrical problem.
Occasionally the Glovebox, Rear tailgate, Aircon (cold air stops coming out, everything else works) and windscreen washers (both front and rear) stops working, all at the same time,
It's so random that it can work one minute, then not the other.
Obviously it's an electrical fault, there seems to be a lose of power to all of these bits of equipment so i need to find something which controls all the systems, like a control module which could be failing?? or a common power supply fuse or cable??
No warning lights come on or idrive fault warnings.
If anyone has had this problem, or has any ideas please let me know.
Thanks.
Strange electrical problem, help needed. - Now sorted.
paulrog
Re: Strange electrical problem, help needed.
Not necessarily the issue but check....
Battery earth connection is tight at the battery.
Battery +ve cable is tight at the battery and under the bonnet at the jumper point.
Battery age and condition. Aging batteries will cause the car to shutdown systems.
Any sign of damp in the fuse board.
Any sign of corrosion in the fuses.
It could be a bad earth behind the glovebox - there are a couple of ‘comb’ connectors behind the dash which if loose could cause connection loss.
Just a few things that spring to mind. Others may chip in with places to look too.
paulrog
Ok, i've replaced the battery with a like for like battery and coded it.
The fault still exists!!!!
So the things which don't work are -
Tailgate
Air con
Glove compartment.
Front & Rear windscreen washers.
The fault seems to be getting worse as these don't work now most of the time.
Really strange, checked all the fuses in the 2 fuseboxes and no problem, checked to see that all plugs are connected ok. checked all the connections near the battery and no signs of corrosion anywhere.
Anyone with any good ideas?? Before i finally take it to BMW.
Thanks.
Tailgate
Air con
Glove compartment.
Thanks.
- moggyboy
This is a long shot but pull open the cover on the right side of the boot and check down in the cavity at the bottom underneath the fuse board to see if it has water in it.
Mine did some time ago and corroded the copper wires causing all sorts of erroneous messages and faults.
Hope this helps.
Hope this helps.
paulrog
Thanks for your help, unfortunately i found no sign of water at the bottom of the boot or anything corroded.
Still no joy, i'll have to book it in the BMW soon to repair the fault.
I've Googled the issue but can't find anything which points to the problem, I thought maybe a faulty
module, but i ran carly and no specific fault codes came up for the issues i'm getting???
paulrog
Re: Strange electrical problem, help needed. - Now sorted.
Just for anyone who starts getting weird problems with the electrical systems on the car, I've finally found the fault and everything now works.
So after i checked the fuses and then replaced the battery which made no difference, I looked for any fault codes, that was a positive step as there were a few codes that pointed to my problems, now as all the problems are connected because they are either all working or all not working I started looking for a common connection, and i found the electronic module which provides the power to all of them is called the Electronic Junction box which is located in the passenger footwell just next to the fusebox.
This Electronic Junction Box is a central part of the car's electrical system, there is a long list of equipment that it controls and powers.
So i took it to BMW, I talked to the technician about what i thought and after a couple of hours they diagnosed it and it was replaced and programmed up.
So it's all working now, it's an expensive repair £715, the cost of the box was only £300 but i had to pay for an hours fault diagnosis, cost of replacing then programming.
OnlineLeslie
Thanks for posting back sometimes you just have to pay the dealer as no one else can sort it although it sounds like you did the hard work but few parts seems to be plug and play anymore ! I'm sure you are glad its sorted anyway
- moggyboy
I'm glad you've got it sorted but ouch with the price.
