Assuming that your tyres are still legal in terms of tread, how long would you keep a set on your car?
I’ve seen advice that suggests any tyre should be replaced after 6 years due the the deterioration of the rubber compounds used, and given the winter set on my X6 are about to hit 8 years but are still legal, I just wondered what others on here would be thinking?
I am about to replace them anyway because the tread depth is about 3mm all round which is borderline useful in any event and I know most tyres go off performance wise at 3mm or less.
I only do about 5k a year which is why they have lasted so long - though on my second set of summer rubber.
Tyres - how long do you keep yours?
sid10
Re: Tyres - how long do you keep yours?
I read somewhere the other day 10 years is the maximum, but normally change winter tyres at 4mm, as the aren't as effective under this unlike normal summer tyres. Pm me as I have a set of 19" X6 alloys and tyres for sale dated 2014 fronts 6-7mm rears 4.5-6mm all vredestein 4 extreme as X5 E53 has been sold which is what they were on with spigot rings.
Regards
Regards
- sleepyfolk
I’d say 7 years at most, the Michelin’s on mine were 9 years old and had enough tread on but there was cracking in the sidewalls so I put new ones on. I tow a caravan occasionally (not with the X5) and you’ll find similar advice in the towing community - usually consensus is 5-7 years but rarely do any get changed because they’ve run the tread down.
Mercedes CLK 320
Audi A6 Quattro 2.4
Mercedes CLK 320
Audi A6 Quattro 2.4
My experience of winter tyres was they age much quicker than summer tyres due to the use of natural rubber which is why they remain flexible at low temps .Unfortunately this is quite prone to cracking and letting water into the cords/canvas which rots it out.
I've actually had 2 inner sidewalls fail at different times thankfully at very low speed (nokian winter tyres ) which were around 6 years old so if I got winters again after about 3 or 4 years run them though the summer to wear them out and replace
I read somewhere Michelin I think recommends 10 years as a max .
