Anyone know what will fit? Bit different from the E53 and E70 models I have had where there were lots and lots of choices by just picking a set of 'SE' wheels of the same model.
The M seems a bit "special" that it probably means that I can't get away with a standard set of wheels as the rims have to be 20" for starters.
Any wheel gurus that can advice on what will work without issues?
Winter wheels / tryes for the X5M
- pvr
911 50th anniversary -
Re: Winter wheels / tryes for the X5M
Have a look on Realoem under ‘Retrofitting’ as it lists the specific sets for winter against your VIN.
Check that TPMS and SSR (runflat tyres) are fitted too. Some sets don’t use SSR or RFT tyres but all should have TPMS - assuming you car has the wheel sensors on them?
Never anthropomorphise computers. They hate that.- pvr
Thanks - will do that.
Will have to check on the sensors, not sure about that.
If the tyre pressure warning system on the iDrive gives you pressures per wheel, you have TPMS sensors on each wheel.
Jan 2018 builds have this set only.
Non-run flat but with TPMS....Style 611M
https://www.realoem.com/bmw/enUS/showpa ... Id=03_4474
£4000 :'(
Let me set up a crowd funding page on xdrivers
Thanks as always X5Sport
- mogsyman
We have bugger all snow down here so don’t be a big girl and just drive it on normal wheels and tyres
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
£4K......hmm about an hour of your time then
BMW want £2k for the 220xD Gran Tourer set - and that’s through this ere Forum (cheers guys at Coltswold, I am considering it).
[quote="mogsyman"]
Skiing, I use the jeep for the UK.
