bmw diagnostics
fennmd
bmw diagnostics
hi
does anyone know what system bmw use for diagnostics,and is it available
thanks
thanks
Entwicklung34
Re: bmw diagnostics
Hi there. I dont know what BMW would be using but INPA is a great piece of diagnostic software for home use and is well worth investing in.
A Blair
Re: bmw diagnostics
I use a Rockwell Scanner and so far it's been excellent diagnosing:
Throttle body fault
Vent valve tank
Air suspension.
What it cannot do is change any of the program settings such as headlight wash frequency.
Throttle body fault
Vent valve tank
Air suspension.
X5 E53 2005 4.4 Sport. Toledo Blue
Things to consider.
Radio. (something in
Detail Car.
Things to consider.
Detail Car.
Re: bmw diagnostics
[quote="A Blair"]
Throttle body fault
Vent valve tank
Air suspension.
Do you mean Foxwell the nt510 by any chance.
Throttle body fault
Vent valve tank
Air suspension.
- marti
Re: bmw diagnostics
BMW use Rheingold diagnostics available on eBay:
https://www.ebay.co.uk/itm/BMW-2019-RHE ... 2465360498
A Blair
Re: bmw diagnostics
Hi Alan
Its a Foxwell 644 Pro. I also bought a cable with CD software that is BMW specific but have not had chance to test it. That engine management light costs me £65 to £75 to reset. So far the BMW has had three resets and another car I have 1 reset. I also reset a mates airbag for a cup of tea and twix bar.
I think if you are going to own a more mature car this sort of stuff along with the forum is invaluable.
Things to consider.
Detail Car.
Things to consider.
Detail Car.
kanewesley
Re: bmw diagnostics
INPA is rubbish, crap unless you go on a one week course for it.
For the D.I.Y'r at home you want BMW scanner 1.4.0.
It's a swine to get going on anything other than Windows XP but is most easily usable by most of us at home.
kanewesley
Re: bmw diagnostics
.....Oh....and you need to be able to read, speak and write in German to use INPA !!!!
- henrym3
Re: bmw diagnostics
Danke Schon
kanewesley
Re: bmw diagnostics
LoL ( laut auflachen)
Re: bmw diagnostics
Google Übersetzer
zufällig
zufällig
- marti
Re: bmw diagnostics
I have INPA, works fine and is in English....
- marinaman
- Contact:
Re: bmw diagnostics
i find the 1.4.0 works fine for the fault code checking and a few other things. that INPA is far more involved but really hammers the battery , mine was nearly flat after an hour messing trying to get the webasto working.
Re: bmw diagnostics
If playing with most of the diagnostic tools you are well advised to have the car on a charger. It’s not INPA that hammers it but the fact that the electronics are all awake and using power. As I have said elsewhere, these cars are power guzzlers. My X6 draws almost 60A just with the ignition on and doing nothing, and I run out of charge in 20 minutes or less. I have a 10A charger in ‘supply’ mode - feeding a constant 10A in - to keep up, or need the engine running.
