Eh Up all,
Car passed its MOT this weekend - not even an advisory.
However when i nipped under the ramp i noticed the brake lines and the fact you cannot see them under the plastic cover. I remember Sleepfolk doing some major work last year on his.
Does anyone know how these covers come off - it looks like they are traditional screw type fixings rather than plastic , Its a shame because i am betting they are a sod to get off.
I want to get the cover off and before i start wondered if anyone had done this, if so how and what to buy fixings wise in advance.
Cheers for all the help.
Brake Pipe - Underbody Plastic Cover Removal
ttr
BMW X5 E53 3.0D Auto Sport 2006
- marti
Re: Brake Pipe - Underbody Plastic Cover Removal
Some can be...give them a good spray of WD...wire brush, make sure you get the socket on nice and snug...think they are 6mm or 8mm ???
Have a look at newtis.info for instructions on taking stuff off.
ttr
Marti
Cheers for that, looks like some are plastic plug / rivet type fixings which will be a bu**&er no doubt!
X5sport
Cheers looked on it but not too helpful in my case but good reference point I will use again
Looks l8ke I can sneak of the main cover without removing the inner wheel arch covers and outer cill cover too, just peel it up ( easier said than done I bet - bit like the old Haynes manual terms “ ease off” and “ refit is reversal of removal”
X5sport
- marti
The plastic rivet type are not to bad just ease out the rivet with a small screwdriver and thin nosed pliers then ease out the base the same...the rivet heads do sustain slight damage but do refit....a spray of WD does help things....
ttr
Marti
Cheers - if they are the expanding plastic pop rivet type with the push in centres, should be able to manage these.
Got used to these on other bumper/trim fixings so will use my pry tools.
Fingers crossed the lines will be ok
thanks again for the help.
- marti
Thats what they are
